Help Required ASAP
Pal318is
Post Wed Jan 03, 2007 9:37 pm
Guys,
I just went out to start up the car to go out.....but it's not starting :?
I thought it was petrol, as this is what i was going out for, but i've gone out and got some petrol and still no joy?? it's ticking over, but just not firing up. it's been stood still since yesterday, but that's all.
Thanks in advance
Pal
Pal
Image[img]http://Image
Dan318-is
Post Wed Jan 03, 2007 9:38 pm
Dude it could be anything; check everything isplugged in correct; remember you need fuel & spark to start as well as a good compression.
Have you tried giving it some beans while cranking it?
Pal318is
Post Wed Jan 03, 2007 9:43 pm
yeah i have, i've also checked the leads too....
I seemed like it was about to start up, turned over then just died :?
would i need to let the fuel, get into the system 1st?? i've rocked the car a few times too...
Pal
Pal
Dan318-is
Post Wed Jan 03, 2007 9:45 pm
If youve run the system dry it can take a while for it to get through. I had my fuel rail of and drained at the weekend and it took a good five minutes of cranking before it fired; were you clean out of petrol?
Sounds silly but the battery has enough power doesnt it?
320Touring
Post Wed Jan 03, 2007 9:46 pm
crank sensor mate- take it off, and clean it up :cool:
smithy318i
Post Wed Jan 03, 2007 9:47 pm
check for spark at the coil.
then check the fuel supply.
perhaps the pump has jambed up because of "bits" floating in the fuel.
cass1_5503
Post Wed Jan 03, 2007 9:48 pm
if its just making a clicking noise then it sounds like the battery, it happend to me this morning outside mcdonalds
smithy318i
Post Wed Jan 03, 2007 9:49 pm
Dan318-is wrote:If youve run the system dry it can take a while for it to get through. I had my fuel rail of and drained at the weekend and it took a good five minutes of cranking before it fired; were you clean out of petrol?
it shouldnt have taken 5 minutes.
Pal. you dont have an M10 do you ?
Pal318is
I tried jump starting it with some leads, but no luck?? Once i'd taken off the leads the battery seemed like it was dead?? but seemed ok before I tried starting her up..
320Touring wrote:crank sensor mate- take it off, and clean it up :cool:
Excuse the dumbness, but were is the crank sensor?
Thanks Again Guys
Pal
Pal
Pal318is
Post Wed Jan 03, 2007 9:50 pm
smithy318i wrote:
Pal. you dont have an M10 do you ?[/quote]
M42 bud
Pal
smithy318i
Post Wed Jan 03, 2007 9:51 pm
cass1_5503 wrote:if its just making a clicking noise then it sounds like the battery, it happend to me this morning outside mcdonalds
does it just turn and turn and turn? or does it just stop half way through a cycle?
320Touring
Thanks Again Guys
Pal
Its at the front of the engine, at the crank pully- easiest way to find it is lie under the car, directly below the kidney grill and have a look- its like an HT lead pointing near the crank
Post Wed Jan 03, 2007 9:53 pm
Pal when you say ticking over do u mean from the starter motor?
Pal318is
Post Wed Jan 03, 2007 9:54 pm
Thanks Again Guys
Pal
Will give this a go, but will give it a go tomorrow, as it's :piss: down here at the mo'
Thanks Guys
Pal
Pal
cass1_5503
Post Wed Jan 03, 2007 9:55 pm
it was just making a ticking noise i got it started in the end someone lent me a jump start pack, (no probs since touch wood)
appletree
Post Wed Jan 03, 2007 9:56 pm
You Should be able to hear the fuel pump buzz when you turn the key to the first position and then it will stop once its got pressure (feuls at the injectors) not 5 mins.?
heard you can damage the pumps if you run them dry as they use the petrol for lubrication, IIRC :D
Dan318-is
Post Wed Jan 03, 2007 9:57 pm
It turned out my coils werent connected properly either so that probably didnt help so give or take
smithy318i
Post Wed Jan 03, 2007 9:58 pm
sounds like your battery is fuckd then!
check to see if the dash lights are dim when you try and start it 2moro.
Pal318is
Post Wed Jan 03, 2007 9:59 pm
appletree wrote:You Should be able to hear the fuel pump buzz when you turn the key to the first position and then it will stop once its got pressure (feuls at the injectors) not 5 mins.?
The pumps working as I heard the beeyach make the buzzing noise...
Pal
Pal
cass1_5503
will do cheers
E30Mark
Post Wed Jan 03, 2007 10:16 pm
I once had a problem starting my 318iS when it had been left a couple of weeks without using it, one or more of the hydraulic tappets jammed open, causing no compression!
Eventually cranking it over using my van as a jump start it fired, but it took forever to get going. Tried i reckon 20 + times cranking it over... ran sweet as a nut after that, until the head cracked :roll:
PM for details
Pal318is
Post Thu Jan 04, 2007 11:53 am
Got it started this morning after i cleaned the spark plugs...they all had oil on them?? what does this mean pls guys??
I have a spare rocker cover gasket, do i need to replace this?? I was going to use it on my new engine..
Pal
Pal
orangecurry
Post Thu Jan 04, 2007 12:01 pm
are you sure it was oil? Not just wet-looking (because you had petrol spraying on them with no spark) carbon deposits?
Rocker-cover gasket has nothing to do with spark plugs.
Kedge
Post Thu Jan 04, 2007 12:15 pm
Pal, hows it going mate!
If you've got a spare rocker cover set it's probably worth putting it on if the current one is getting on a bit as there is a good chance oil maybe getting through and down to your plugs!
Instagram - Kedge85
orangecurry
Post Thu Jan 04, 2007 12:18 pm
how would the oil get down the plug thread into the combustion chamber? :mad:
I do hope Pal meant they have oil on the gap end, not the lead end?
DRIFTBOY
Post Thu Jan 04, 2007 12:22 pm
Pal318is wrote:Got it started this morning after i cleaned the spark plugs...they all had oil on them?? what does this mean pls guys??
Sounds to me like it was flooded - petrol on the spark plugs and even though there was a spark there was too much liquid fuel and not enough vapour to ignite, I've had that a couple of times with my M30 engine.
That's why it started when you cleaned the plugs!
A possibility.
Kedge
Post Thu Jan 04, 2007 12:33 pm
This is a pic of a rocker cover gasket set, if any of the o-rings perish then oil can leak down to the spark plug.
Instagram - Kedge85
Pal318is
Post Thu Jan 04, 2007 1:37 pm
Hi Kedge,
I'm not to bad mate, just can't get my new engine sorted soon enough :cry:
That's exactly the one i have Kedge (rocker cover gasket set), there was more oil on the plug closest to the front than the rest. I cleaned them up and then jump started it and hey presto :mad: the thing started...I took it for a good run and left it running for a good half hour, seems to be ok at the moment.
I've not bothered to change the gasket, as I have a strut brace on the front and couldn't be arsed...looks like i'll have too know.
Thanks for all the help from everyone...love the zone :group:
How's your car Kedge??
Pal
Pal
Kedge
Post Thu Jan 04, 2007 1:42 pm
Good to hear you've got it going!
My cars not doing so well, see my topic about the oil! The old engine blew it's profile gasket so took it out and i'm planning on squeezing a few more ponies out of it one way or another, the engine I got hold of to replace it for the mean time is turing out to be a right head ache, not driven the car for a fair few months now :cry:
Instagram - Kedge85
orangecurry
Post Thu Jan 04, 2007 1:47 pm
http://www.e30zone.net/modules.php?name ... ht=m42+oil
so Pal - have you done anything about this... since Aug 2005? winkeye
Pal318is
Post Thu Jan 04, 2007 1:53 pm
orangecurry wrote:http://www.e30zone.net/modules.php?name ... ht=m42+oil
:rofl: winkeye good find!!
I did say i can't be arsed... winkeye
Seriously tho' got so much stuff just sitting at home for the car, i know i really need to get it sorted :o:
This is the year it will all finally get done, lost my way a bit and really couldn't be bothered with the car, but that's all gonna change soon...
Pal
Pal
