Solid diff mounts
topi
Sorry if this has been covered before, I did try searching it.
I've made a couple solid aluminium diff mounts for people in the past, and was wandering about doing the same for mine? Are they really a good idea? I keep getting the "its rubber mounted for a reason" thoughts. But with the drifting, the rubber ones don't stand up to much.
kam-325i
Just think, if the diff mount is soild....where is all of the tension/vibration going that noramlly wears out the rubber one's ???
These are ok for track slags/race cars.....but not really any use for everyday cars.......
topi
Yeah I was kinda worried about cracking the diff casing etc. I don't suppose there's anywhere that sells decent rubber or alternative mounts for a good price?
- Homo Hair
Z3M bush is a BMW upgrade
If not i believe Powerflex were gonna start making them..
Theo
get the solid z3m bush, reduces movement and is a staight swap.
topi
Sounds a bit pricey. Any reccomended place of purchase?
yes there is! the BMW dealer, your after a ZM3 coupe diff bush. It's like an E30 one but has 2 extra metal bars in it and it seems to last and take alot more sh!t than the standard bush wants to. It's only around £2 more than the standard E30 bush iirc.
I'm not sure how much serious drifting it would take but the one i fitted to my old sport took 2 trips to the nurburgring and a whole day's drift practice and was still going. Plus all the crap i gave it on the road
i think metal diff bushes are like having metal engine mounts and not very good but i have no experience of them
hth
hth
eko
- Old timer
Jhonno have you used one of these?Jhonno wrote:Z3M bush is a BMW upgrade
If so how much was it,im at the dealers on friday to get a rear bush kit and wouldnt mind fitting one of these if `the price is right`
- Homo Hair
it was about £40 iirc got the reciept somewhere
slightly stiffer as Si says, longer lasting elso (just like the missus ordered
topi
Hmm see I'm quite keen on making myself at just material cost hehe. Whaddaya reckon to a solid nylon or similar material bush instead of aluminium. Still has a little bit of 'squidge' to it.
eko
- Old timer
fecking hell £40Jhonno wrote:it was about £40 iirc got the reciept somewhere
slightly stiffer as Si says, longer lasting elso (just like the missus ordered![]()
topi
Gah, see this is the problem. Coming from the Ford background, EVERYTHING was £12 from the dealer. Though I still tried to make it all myself instead.
eko
- Old timer
Topi,being an ex Ford man myself,in comparison BMW dealers are much cheaper than Ford dealers for replacement parts,in relation to age of car of course!
Always an exception to the rule though.
topi
Really? Maybe I'm getting the dealer and the scrapyard mixed up or something ha.
Ziggy
I've got one... twas under £40 but more than £35 IIRC... can dig out the receipt if it really makes any difference!
eko
- Old timer
ill just play it by ear on friday,if ive got enought spare cash ill pick one up!
Ziggy
I'd say if your diff bush needs doing, it's worth getting the better one... Doubt you'll really notice much difference otherwise though, so just wait 'til it needs it
