quick timing question
noney82
Post Wed Jan 03, 2007 8:03 pm
are these the right marks to line the timing up with? am i now safe to take the belt off?
noney82
Post Wed Jan 03, 2007 8:09 pm
iv got the car in bits now so any help would be very greatfull
:eek:
Chris-W
Post Wed Jan 03, 2007 8:11 pm
Small pics, but: yes.
noney82
Post Wed Jan 03, 2007 8:13 pm
thats how they came up shall i email them?
Chris-W
Post Wed Jan 03, 2007 8:14 pm
Nah - whip the belt off.
Do you still have that 4-pot for sale?
noney82
Post Wed Jan 03, 2007 8:17 pm
changing water pump so doing cambelt to
cheers mate, when i put new one iv got to turn engine over from bottom pully few times make sure they stay lined up?
320Touring
Post Wed Jan 03, 2007 8:23 pm
*takes notes as hopes to be doing similar in not too distant fuftre*
noney82
Post Wed Jan 03, 2007 9:40 pm
cant get the bottom cam cover off, how does the bottom crank pully come off cos thats stopping the last 10mm bolt coming out the cover
kam-325i
Post Wed Jan 03, 2007 9:44 pm
Its bolted.......6 bolts if i remmeber rightly......
noney82
Post Wed Jan 03, 2007 9:46 pm
kam-325i
Post Wed Jan 03, 2007 9:47 pm
noney82 wrote:Image
I had the same problem. Pulley has to come of.......Its held on with 6 bolts just around the big sticky out thingy.......
noney82
Post Wed Jan 03, 2007 9:48 pm
thats the vibration pully thats off its the one in the pic thats the twat
noney82
how did you get it off mate
kam-325i
Post Wed Jan 03, 2007 9:49 pm
noney82 wrote:thats the vibration pully thats off its the one in the pic thats the twat
6 bolts hold it on........you cant see them, but you can feel them in the recess......
noney82
Post Wed Jan 03, 2007 9:50 pm
the one thats held on with 6 bolts is off
kam-325i
Post Wed Jan 03, 2007 9:51 pm
if the pulleyis off, the bolt should come out.....
kam-325i
Post Wed Jan 03, 2007 9:53 pm
its all one part..........
noney82
how do you undo it tho cos when you get spanner on it, it just turns the whole crank and belt etc, need to hold something against to stop the engine turning but what?
kam-325i
Post Wed Jan 03, 2007 9:55 pm
spanner on the big nut bit on the end bit sticking out....
noney82
Post Wed Jan 03, 2007 9:59 pm
iv done a quick video to show what its doing
kam-325i
Post Wed Jan 03, 2007 10:01 pm
I know i had the same problem.
You hold the crank with a spanner/socket on the end/nut looking thing.......it can be a bit arkward.......
noney82
Post Wed Jan 03, 2007 10:03 pm
kam-325i
Post Wed Jan 03, 2007 10:07 pm
i can see now......
if you have taken out the 6 bolts........you need to persuade the pulley/damper to come off with a "something" from behind......
Chris-W
Post Wed Jan 03, 2007 10:09 pm
Time for a persuasion tool.
noney82
Post Wed Jan 03, 2007 10:19 pm
right so there is nothing holding the big crank pully on now its just stuck
kam-325i
Post Wed Jan 03, 2007 10:28 pm
no......nothing......
dont turn it, as it has a small peg/key to hold it in the right place on the crank, it needs to be levered forward.
the pulley and toothed bit are one machined peice.......
noney82
Post Wed Jan 03, 2007 10:34 pm
ok thank you guys im on a mission now lol
noney82
Post Wed Jan 03, 2007 11:47 pm
iv got it off woohooo but calling it a day cos i cant split the fan nut off the water pump, thank you for all your help i shall return if i get stuck again which is more than likely lol
Martinaston
Post Thu Jan 04, 2007 12:18 am
Buy a new fan belt and use a pair of mole grips to hold the old belt around the pully to stop it turning while you undo the fan (reverse thread) and then do the same while you take the four bolts out of the pully as well.
To be sure you get the timing belt back on in the same place mark the belt and the tooth its on of each cog (pully) and then lay the belt on top of the new one and mark the same teeth, then put the new belt on so the marks line up with the marks on the pullies.
Its an extra step so you know the belts on the same as the original without having to climb in the engine bay to check it but is also another chance to f**k up :mad:
There is NO nucleus.
noney82
Post Fri Jan 05, 2007 4:05 pm
good news guys she works fine, had problem with getting water pump to seal but she there now, finally finished early hours this morning. thank you all for your help on this couldnt of done it without you :D :D :D :D
