310mm Wilwood brake kit
325zimmer
Post Tue Dec 19, 2006 11:04 am
Has anyone on the Zone bought it or has any experience of this 310mm Wilwood brake kit from rally design?
I'm possibly quite tempeted, but want to know what people think of it.
Does it require the master cylinder changing to a different size diameter for better braking?
Will it also work with the ABS on the car?
Pav
325zimmer
Post Thu Dec 21, 2006 8:56 pm
Anyone?
Turbo-Brown
Boost Junkie
Post Thu Dec 21, 2006 9:43 pm
I've got the 280mm kit on mine.
It's great, didn't need to change the MC and even with rubber hoses the pedal's nice and firm.
The calipers with the bigger kit are the same so that should also apply :D
Do ring them up and check the clearance you need inside the wheel between the mounting face and the back of the spokes as it's bloody tight on mine and mine fit more through luck than judgement as I've got classless gay looking wheels.
No reason why the ABS should be effected, all that's looking for is whether a wheel's decelerated quicker than it should have to determine whether it should cut in.
Don't forget though that the tyre does the stopping of your car so your ultimate stopping distance isn't gonna change drastically unless the standard brakes are prone to fading from high speeds in which case bigger brakes are a big plus :)
325zimmer
Post Fri Dec 22, 2006 10:40 am
Cheers for the advice.
I will have to speak to Rally design to get the dimensions.
As long they get under my BBS 15" and my BK171 17" i'll be happy!!
Cheers :D
Andy335Touring
Post Fri Dec 22, 2006 1:36 pm
They won't fit over 15's
ed325i
Post Fri Dec 22, 2006 4:25 pm
What about the wms ones ? Look here >> http://www.e30zone.net/modules.php?name ... ic&t=34867
Post Fri Dec 22, 2006 5:56 pm
restricted area? :?
keri-WMS
Post Wed Jan 03, 2007 5:36 pm
ed325i wrote:What about the wms ones ? Look here >> http://www.e30zone.net/modules.php?name ... ic&t=34867
Link works for me at the moment - no restricted message I can see?
The WMS 280mm kit DOES go under the 15" BBS's...
Jimbob
Post Wed Jan 03, 2007 5:58 pm
The Wilwood 280mm kit will fit under 15" wheels as far as I'm aware.
I think Andy was referring to 310mm not fitting under 15".
Turbo-Brown
Boost Junkie
Post Wed Jan 03, 2007 6:08 pm
Think you'd need spacers with the BBS wheels, the calipers stand proud of the wheel mounting face of the disc by quite some margin.
It was pure luck that the wheels I ended up buying cleared the calipers.
