Relocating the alternator on M20 2.5
Post Tue Jan 02, 2007 5:27 pm
Is it possible? Has anyone moved it to say where the aircon compressor (sp) is?
i'm doing a little project i'm mincing around with an M3 airbox, i've made up a plate to get a 325i AFM to mate up with the airbox and sourced a small M20 rad off a C-reg 320. This is not too bad but it doesn't help having a facelift 2.5 engine as the header tank is on the opposite side to the old engines! The rad is small enough which is good but now the bottom of the airbox will foul the alternator.
Otherwise i'll have to maybe make a bracket to mount the airbox+afm a bit higher up, but i can't go too high or the bonnet will not shut.
Should add a bit more low end/mid range grunt for a 2.5 i'm hoping. I'm not sure anyone else has ever done this?
Post Tue Jan 02, 2007 5:31 pm
It's the sort of thing the kit car boys do often enough. Shouldn't be any problem in fitting it the other side with a little fit of fabrication.
I found I could mount the airbox on my M50 E30 surprisingly high up and still clear the bonnet.
Post Tue Jan 02, 2007 6:20 pm
Brian do u have a photo of it please? or is that asking too much!
Post Tue Jan 02, 2007 9:27 pm
Simon13 wrote:Brian do u have a photo of it please? or is that asking too much!
Photo of the airbox, I presume; my alternator is where BMW intended. Don't have any ready taken, but I could take one sometime.
The reason I lifted mine, IIRC, was to get clearance between the air pipe and the nose of the brake master cylinder. After lifting it, I realised that I could drop the front down and that would raise the pipe more, so then I could drop the back a bit again as well.
Simon
Post Tue Jan 02, 2007 10:30 pm
Simon, have you acually test fitted the airbox? I know looking at mine the airbox has a sort of bend in it to clear the S14 alternator, and sits very close to it as is...
appletree
Post Tue Jan 02, 2007 10:41 pm
i'm sure you probly have checked the space under the bonnet when it shut but if you havent then its deffinatly worth doing, i was very suprised with the avalible space.
i did it by taking out the front middle BMW grill and lowering the radiator off its mounts to see through the gap.
You could put a "sausage" of of blue tak on the cam cover and keep adding to it till i touches the bonnet.
Hope that helps :D
Post Tue Jan 02, 2007 11:58 pm
Cheers for the help guys,
I see Simon so it's close in S14 guise too. I test fitted it all today on my touring as it's even more aggro on the auto. I fitted the rad etc so i had more clearance on this side. The rad gave the clearance i needed but as i thought before i started the alternator is right in the bloody way. I'm sure with a little thought the alternator swopped over to the other side wii cure all the problems. Then i need to remove the plastic panel and let the air in there as the end of the box is right up against a flat plastic panel so thats no good either! I'll have to look at Demlots chariot when i see him next.
In the coming time i shall use the spare car before it's scrapped as a test bed. My old auto does come in handy!
I could, thinking about it "modify" lol the the bottom of the airbox, but i really don't want to cut this up/do this as i managed to get hold the later bigger/better M3 box. Which i'm sure has a value to the M3 massive. I think it's the one fitted to late 215bhp cars and the sport evo etc?
The car revs up alot quicker when it's just lobbed on so there could be something there. If it gives the 4 pot more grunt it should help a 6 pot. If i can get it right on one of my sh!tters it might find it's way onto the alpina later on.
The next issue after fitting it is tweaking the fueling as i don't think the ECU will recognise the extra fuel coming in? I know a remap or standalone management will reap the best benefits but i'm not going down that avenue/at that stage yet!
I'm sure there is a way somehow!
smithy318i
Post Wed Jan 03, 2007 3:36 pm
Post Wed Jan 03, 2007 5:34 pm
Now were cooking on gas! :D Where did u find that smithy?!
smithy318i
Post Wed Jan 03, 2007 5:38 pm
Post Wed Jan 03, 2007 9:11 pm
Cheers i havn't been on E30tech for a while
