wet seats
tbmw
Post Tue Jan 02, 2007 9:42 pm
just found my rear seat to be absolutely soakin wet and cant see any leaks
is this likely to be the door seals or some other issue?
thanks in advance
T
A clear conscience is a sign of a bad memory
kevo
Post Tue Jan 02, 2007 9:44 pm
if she was sat in my passenger seat i'd have a wet drivers seat too! seriously though try gettin someone to pour water onto the car whilst sitting in it and looking. did you leave your sunroof ajar and not notice?
kev
jcjdavis1
Post Tue Jan 02, 2007 10:06 pm
Hi my n/s rear door window sometimes slips down a wee bit letting in water might be worth checking.
orangecurry
Post Tue Jan 02, 2007 10:35 pm
so you have a 4-door? I'm guessing from your sig here.
With sunroof?
tbmw
Post Wed Jan 03, 2007 8:01 pm
yea it has a sunroof
dont think it could be the window slippin down a bit cos there is no wind noise from it but the seat was absolutely saturated
Post Wed Jan 03, 2007 10:56 pm
There is a "gutter" attached to the fabric part of the sunroof that sits directly under the rear seal of the sunroof when it's closed, and it's quite common for one end of this gutter to rot off and slip out of place.
Much more serious would b rotted sunroof drain tube stubs at the back of the roof.
