I have a 1990 320i touring. Ever since I got it in 2000, it has suffered a problem where between 1000 and 1500 revs, when between accelerating and no throttle, is starts kangarooing. Since 2003 have replaced the aitflow meter, all the inlet hoses, the idle bypass valve, the throttle body, all injectors, the cylinder head incl cam, valves, springs etc, and exhaust manifold with new parts. This problem has never been eliminated. I am sure there are no leaks in the inlet manifold and the oil system.
It has to be something daft. The rest of the driving range is first class. Someone must have had this bug sometime, please help.
unstable running bug
Martinaston
As you've changed most other things already then you may as well carry on and rebuild the gearbox
to remove the slack in the idler shaft and then just replace the clutch to remove the worn out springs that are causing the problem.
There is NO nucleus.
funkyjoe
thankyou for the response but you are way off the mark. The problem is definitely fuel/ECU/injector/air leak related. The gearbox is fine if a bit old and the clutch is good having been replaced in recent history. Were the problem in the gearbox, the fault would be apparent in more than a tiny range and wouldn't feel like the injectors going on/off rapidly in an underdamped second order transfer function fashion.
The fuel pump is fine in tests too.
Could someone have set the mixture too rich in the ECU?
kam-325i
I had a similar problem on my 320i which was caused by a knackerd TPS.
funkyjoe
I have replace the TPS, and also when the new throttle body came, it had the TPS fitted and calibrated, so in fact fitted two new ones. I noticed that the old throttle body did not fit new TPS's, the adjustment range seems to have been changed in the design cycle of the car at some point.
Thanks for that suggestion but still no joy there.
DaveD
- E30Zone Wiki Specialist
have you thought about an electrical glitch ie ht leads or distributor
smithy318i
if you read through this topic, we are having the same problems.
http://www.e30zone.net/modules.php?name ... t=kanga%2A
