central locking still not working
david106
Post Sun Dec 31, 2006 10:10 pm
I've had this problem with my central locking since i bought the car. I've asked for help and everyones been great i thought I'd fixed it by cutting the red/black wire it worked for about a week now it's knackered again .
I've even tried another relay but still i hearing this clicking noise everytime i turn the key it's really pissing me off now.
Is it normal not to be able to undo any of the other doors if the central locking fails because i can't even pull the buttons up on any of the doors except the drivers door.
Post Sun Dec 31, 2006 10:23 pm
Other doors won't open if the deadlocks are engaged. Dig out the locking ECU from the cill, open it up and check it's not been waterlogged. Also connect a 12V lamp across the red/black and the brown wires at the ECU connector to confirm that the supply is present.
Just read your OP properly, and see that you've tried a (known good?) relay. What condition was the old one like inside, as waterlogged ones can have an annoying habit of engaging the deadlocks and then frying them.
david106
Post Sun Dec 31, 2006 10:58 pm
thanks for the reply the relay is ok no water inside i cant understand why it works perfectly for a week and then stop .
when i had all the wiring out last week its a nightmare under there someone has run a wire from the relay on the drivers side that goes under the dash to the passenger side, i haven't had a look to see where this ends up but when i disconnect it from the red/black wire nothing happens ie no clicking and no power
i hope this makes sense
Post Sun Dec 31, 2006 11:21 pm
If you disconnect the red/black wire then the central locking will be totaly dead - red/black wire is the supply wire to the whole system , so check it's OK by connecting a 12V21W lamp between the red/black and the brown at the ECU, and check that it lights to full brightness.
Regarding the extra wire This could be something to do with alarm activated central locking installed by someone who didn't know the correct place to connect to the locking circuit, or, if you have an interior light delay relay (mounts on the same plate as the lock relay), it could be to make the delay work on the passenger door as well.
david106
Post Sun Dec 31, 2006 11:28 pm
sorry what i meant to say was this extra wire is joined to the red/black wire and when i disconnect this extra wire from the red/black wire it all goes dead
Post Sun Dec 31, 2006 11:49 pm
Sounds like someone has bodged a bypass to the red/black supply wire at some time. You still haven't said if you have full 12V power available at the locking ECU (across red/black and brown).
david106
Post Mon Jan 01, 2007 12:33 am
I will check asap and report back one thing i have noticed is the relay is mounted on a bracket and then bolted to the car if this was loose and not screwed in position would this make any difference ie earthing
thanks for the advice
Post Mon Jan 01, 2007 12:38 am
No, earthing is by the brown wire back to the stud above the glove box.
david106
Post Mon Jan 01, 2007 4:30 pm
Hi brianmoooore,
just to let you know i think i have solved the problem, the relay i thought was good turned out to be full of water somewhere along the line i must of switched them .
I'm breaking another tourer so i used the relay from that and all is well, is there a way to keep them dry like covering it in a plastic bag or something.
Anyway thanks for your help and a happy new year to you.
Dave_M3
Post Mon Jan 01, 2007 5:08 pm
Sorry if this is kind of off the topic a bit but my lock on the drivers door doesnt work properly. When I turn 2 lock it the key turns way 2 far 2 the left and then it gets kind of jammed. Plus it dosent pull the lock fully, U hav 2 pull the latch then central locking locks. Do I just bascially need a new lock nd if I do is it possible 2 use the cars own key slot inside a new lock unit. I had a look at it by taking off the door card nd put grease on it 2 c if it made a diff. Sumtimes it jams sumtimes its fine. :?
Post Mon Jan 01, 2007 5:25 pm
david106 wrote:.
I'm breaking another tourer so i used the relay from that and all is well, is there a way to keep them dry like covering it in a plastic bag or something..
Shouldn't need any additional protection - just keep the drain slots in the sills clear, and don't drive through water more than about two feet deep.
There's no reason really why you cant mount the unit a bit higher up in the car, if you really want to.
