320i - engine problem
wind
Post Sun Dec 31, 2006 6:09 pm
hello everyone
I have a 320i from 1988 with 2.0 engine which now.. died :( Below are vids - if you could tell me what should I do with it - should I get a new engine or try to fix this one? I dont have much cash so cheaper solution is better ;)
I dont know which engines fit to 320 without welding/cutting too.. if you could give me a clue I'd be gratefull. or maybe anyone of you is selling an engine (if so pls pm me)
- engine running when everything was still ok
- as above
- engine running when 'something' happened. I believe its a loose piston
ftp://scirocco:scirocco@www.scirocco-co ... engine.wmv - as above
Im in Lichfield if anyone leves nearby and perhaps could take a quick look..
cheers
Yeti
Post Sun Dec 31, 2006 6:16 pm
its sounds like a rocker has snapped,resulting in
1. the valve has not coming up, so the piston hits it up and slaps the valve on every stroke,
2 and or it probably just could be a rocker broken and the cam is hitting it on every revlolution.
wind
Post Sun Dec 31, 2006 6:25 pm
the last vid is engine running with no cam cover... and everything seems to be ok, nothing is loose..
(last vid is also on utube but its not processed yet :( )
Templ8e30
Post Sun Dec 31, 2006 7:56 pm
A mate had a very siilar problem with his 320i, albeit a louder knock than yours.
It turned out to be a shot oil pump, the low oil pressure light bulb had been removed. Th low oil pressure caused so much wear that the pistons were smacking the head.
When we took the head off there was no carbon on the piston tops were they'd been hitting the head :eek:
Hope it isn't that 8O
Also had an Astra GTE that sounded similar, head gasket had blown between 2 cylinders at the fire rings.
Try doing a compression check, make sure you don't have a blown gasket or a sticky valve
Cheers,
Iain T
2007 Mazda 6 2.0 estate
Templ8e30
Post Sun Dec 31, 2006 7:59 pm
Couldn't quite see if the inlet rocker on cylinder No6 was moving or not :?
Cheers,
Iain T
wind
Post Sun Dec 31, 2006 8:04 pm
there was light showing 'change oil' so tahts what I did... I changed the oil and filter - than the warning light stopped flashing..
Post Sun Dec 31, 2006 9:42 pm
wind wrote:there was light showing 'change oil'
No such light on any E30. There's one labeled "engine oil" if you have the "check" panel in the roof, which indicates low oil level, and which will go out if you top up the oil.
There's an "oil service" light on the service indicator panel of the instrument cluster, which means change the oil amongst other things, but this light won't go out unless it is manually reset.
wind
Post Sun Dec 31, 2006 9:53 pm
hmm.. both lights that you're talking about were on.. I didnt reset anything.. when I topped up the oil lights whent off only for a day so I changed the oil and everything was ok since than. Oil which was in looked normal - no little metal pieces in it or anything like it. Just old oil
Post Sun Dec 31, 2006 10:06 pm
Templ8e30 wrote:Couldn't quite see if the inlet rocker on cylinder No6 was moving or not :?
Cheers,
Iain T
Me, neither. Vid's a bit dark.
Was engine disabled for this vid, or wouldn't it run?
Think you might possibly be misunderstanding me. When any of the roof mounted red LED warning lights are on, there is a light labelled "check" in the centre of the instrument cluster, which will flash until the LED is reset, or the check button is pressed.
The light that needs to be manually reset is above the row of green LEDs plus orange and red LEDs at the bottom of the cluster.
Martinaston
Post Mon Jan 01, 2007 2:40 am
If the oil light was on then i guess you didn't have enough in it. (not good) :(
There is NO nucleus.
Andyboy
Alpina Colada
Post Mon Jan 01, 2007 2:52 am
wind wrote:hello everyone
I'm very sorry to hear that. I hope you find a cure real soon.
wind
Post Mon Jan 01, 2007 3:13 am
very funny, ha ha..
Andyboy
Alpina Colada
Post Mon Jan 01, 2007 3:14 am
We've just come in from the pub and we're wankered.
Ha ha!!
wind
Post Mon Jan 01, 2007 3:18 am
Martinaston wrote:If the oil light was on then i guess you didn't have enough in it. (not good) :(
The light went on when I was going back home from work (15 mile drive). I topped it up when I got back home with Mobil mineral oil and the light went off for two days. Than it went on again so I bought more oil, filter and changed it all. After that everything seemed to be ok.
Engine was not burning oil... there was no blue smoke, only a small black mist (running a bit too rich)
Andyboy
Alpina Colada
Post Mon Jan 01, 2007 3:21 am
wind wrote:Engine was not burning oil... there was no blue smoke, only a small black mist (running a bit too rich)
It hasn't got enough power for that!
wind
Andyboy wrote:We've just come in from the pub and we're wankered.
Ha ha!!
good for ya :thumb:
Andyboy
Alpina Colada
Post Mon Jan 01, 2007 3:23 am
Aye!! :D
wind
Post Mon Jan 01, 2007 3:24 am
send me some cash and I'll put something powerfull enough :woohoo:
Andyboy
Alpina Colada
Post Mon Jan 01, 2007 3:47 am
One of my post Stella farts should be enough!!
