Central locking not working
andye30m3
Post Sun Dec 31, 2006 3:24 pm
Hi
My E30 M3 was sat for a while and the central locking hasn't worked since, It wont work from the alarm or either door, just wondering if theres anything which tends to fail or what to look at first.
Jerran
Post Sun Dec 31, 2006 3:28 pm
Have a look at the control module normally located in the drivers foot well behind the speaker, not sure what side it will be on your M3. If it's damp then it may have given up. Take the speaker out, and it's below that, a black box about the size of a packet of cigs.
Post Sun Dec 31, 2006 3:33 pm
Assuming the M3 wiring is the same in this area as other E30s, do a forum search for red AND black and my username.
andye30m3
Post Sun Dec 31, 2006 3:51 pm
Cheers for the replies i'll have a look at this tomorrow once the new year hangover has gone. :D
Gortour
Post Sun Dec 31, 2006 4:11 pm
If all looks OK in the footwell, maybe try the fusebox?
May have a mild dose of damp in there if it's been sat. Anything else playing up or just the locking?
andye30m3
Post Sun Dec 31, 2006 4:49 pm
Think its just the locking, I've been driving it for around 6 months now but just never got round to doing anything about it.
Gortour
Post Sun Dec 31, 2006 4:56 pm
Doubt it's the fuse then. Would be fuse 27, also working the interior lights, radio and on-board computer.
Back to the control box in the footwell then. Most likely cause of the problem, but just thought I'd ask.
Good luck sorting it.
Post Sun Dec 31, 2006 8:24 pm
It's nothing to do with the fusebox - faulty c/locking doesn't draw enough current to pop the fuse in any case.
Locking ECUs can go faulty, usually as a result of poor maintenance letting the sill drains clog up and flooding the ECU, but this is relatively unusual.
90% of central locking faults affecting all locks are down to problems with the red/black supply wire, as I've detailed many times before.
The only thing I'm not sure of is whether the M3 uses the same wiring arrangements in this area.
Gortour
Post Tue Jan 02, 2007 6:28 pm
Brianmoooore wrote: 90% of central locking faults affecting all locks are down to problems with the red/black supply wire, as I've detailed many times before.
Sorry Brian, not trying to stick my nose in where not wanted, just trying to offer another possibility. IF anything else was wrong as well, there may have been damp as the car has been sat for a while.
Quite agreed that the red/black wire is going to be the problem especially as nothing else is wrong.
kevin316i
Post Wed Jan 03, 2007 12:26 am
Some central locking problems are due to the corrosion of pins in the A-pillar connector. In the case of the 12v supply going into the door, some people put in a hack rather repairing the problem properly, which is lazy and unprofessional. It's not difficult to replace corroded pins. However, it is best to buy the connectors from the main dealer rather than the likes of Farnell. I used connectors from Farnell on my previous E30 and they had rotted again within a year!
Post Wed Jan 03, 2007 12:43 am
kevin316i wrote:Some central locking problems are due to the corrosion of pins in the A-pillar connector. In the case of the 12v supply going into the door, some people put in a hack rather repairing the problem properly, which is lazy and unprofessional. It's not difficult to replace corroded pins. However, it is best to buy the connectors from the main dealer rather than the likes of Farnell. I used connectors from Farnell on my previous E30 and they had rotted again within a year!
No it's not lazy and unprofessionel! The CAUSE of rot in the door connector pins is the presence of permanently live pins i.e. the two connected to the red/black wires, and the best way to avoid further corrosion is to remove these two (unnecessary) pins, or rather, the power feed to them.
Corrosion will still occur in the connectors because of a pin to the mirrors which is live when the ignition is on, but at least the rot will stop when the car is parked.
kevin316i
Post Thu Jan 04, 2007 1:00 am
I understand where you are coming from on this Brian, but any of these type of repairs that I have seen have been sloppily done. One of the reasons for the accelerated corrosion of the pins that are live is that the rubber boot over the connector allows dampness in. My preference is for the proper replacement of the pins and sealing of the rubber boot, as I prefer things to be as original as possible :)
