325 lump 320 wiring loom!!
jamesh1977
- BEWARE Zone Thief
ive read posts about changing engines and needing to change the engine wiring looms. whats the diffrence between the 320 engine loom and the 325 engine loom? please dont think im thick its just wiring is one area where im not really clued up. is it possible to get the 25 running with the 320 loom or do i really need to change the loom. just i thought the 320 and the 325 were basiclly the same engines bar the cc size.
gareth
afaik they're both the same. you'll need to swap the ecu's over though
has to be said though, why not a 3.5 m30?
jamesh1977
- BEWARE Zone Thief
i would do the m30 3.5 but my insurance company might have a thing or 2 to say about it when i get my licence back there not to bad with the 2.5 lump but dont think theyed be as understanding with a 3.5 lump
was really curious as a couple of ppl have said to me i would need to use the 2.5 engine loom which i cutwhen taking it out the car
so was starting to panic i know ill need to use the 2.5 ecu and afm. ive got both but sure there from a preface lift im going to look at the numbers on them as soon as i can get over to the garage and see if someone on here can help me id them
gareth
my 3.5 conversion only costs 10% more than the standard 325i price!
jamesh1977
- BEWARE Zone Thief
my insurance company wouldnt qoute me for a 3.5 yet there qouting me £700 fullycomp for the 2.5 conversion which was the cheapest i could get
Even the ECUs are the same apart from the chip. so, if you intend to fit a zone chip, you can even keep the 320 ECU.gareth wrote:afaik they're both the same. you'll need to swap the ecu's over though
jamesh1977
- BEWARE Zone Thief
could be looking into a zonechip in the near future how easy are they to get fitted? what price is on the chips ?
gareth
i'm with adrian flux if that helps.
jamesh1977
- BEWARE Zone Thief
ill give them a call after the new year and see the qoute they can give me always worth a shot as you never know i might 3.5 my next one. just the now ill get my licence back late febuaray early march so im hoping to have mine on the road for then
- **BANNED**
I looked at the article on the zone when I changed my chip,bought the replacement from the zone shop.Quick service and it works as described.
jamesh1977
- BEWARE Zone Thief
yea i know that ive got the throttle body and afm sittin here its just the wiring loom i was wondering about
jamesh1977
- BEWARE Zone Thief
been away looking at a 325i sport today and im sorely tempteds to call it a day with the 320 idea and buy the sport as its at a sensible price so i can see me selling loads of tech 2 stuff soon watch this space
drewjak
just take the engine out with the loom on it,its so much easier than taking all the plugs off the engine!, unplug it from the ecu and pull it throught the bulk head.
jamesh1977
- BEWARE Zone Thief
you tell me that after the 2.5 engine is sitting in my shed after getting the wirring loom cut
- **BANNED**
This may not apply,but when I swopped manifolds to fit a 325 manifold to the 2.7 I found that the injector wiring case fouled the fuel rail,on the 325 one the fuel return was at the back of the fuel rail,on the 320 one the return was by the feed.I do not throw anything away until I am certain I do not need it,and I try not to cut or break any item for the same reason.Er indoors calls it rubbish,I call it treasure..
jamesh1977
- BEWARE Zone Thief
ive got the manifold for the 325i engine its just the wirring loom that i was worried about
Andyboy
- Alpina Colada
Keep the 320i ECU, restamp the block with the 320i engine number and carefully 'lose' the '2.5/2.7' number from the head.* Don't tell the insurance company anything.
*Not that I would do this, of course.
drewjak
never mind m8, its all a learning curve, i was ready to sack my engine swop because off the wireing, if you look at the pic the hole is to the left of the white tiewraps, next to where the battery goes. when putting the big grommet back in smear it with a little grease or some kind of lube, other wise its a pig to get in proply.jamesh1977 wrote:you tell me that after the 2.5 engine is sitting in my shed after getting the wirring loom cut
a little tip also(if ya dont all ready know) notice how the back end is right in the air to make the engine come out easily.
jamesh1977
- BEWARE Zone Thief
the thought has crossed my mindAndyboy wrote:Keep the 320i ECU, restamp the block with the 320i engine number and carefully 'lose' the '2.5/2.7' number from the head.* Don't tell the insurance company anything.
honest officer that was the engine that was in it when i bought it its just a quick 2.0 .......
jamesh1977
- BEWARE Zone Thief
cheers for the info i thought it would be easier dropping it down the way with the subframe ectdrewjak wrote:never mind m8, its all a learning curve, i was ready to sack my engine swop because off the wireing, if you look at the pic the hole is to the left of the white tiewraps, next to where the battery goes. when putting the big grommet back in smear it with a little grease or some kind of lube, other wise its a pig to get in proply.jamesh1977 wrote:you tell me that after the 2.5 engine is sitting in my shed after getting the wirring loom cut
gareth
i did my m30 swap from below and it's easier than some i've done from above. you'll need to get the front about 850mm up from memory which is a bit hairly unless you have a nice ramp of course!
jamesh1977
- BEWARE Zone Thief
got use of a wheel free ramp for the engine change so should hopefully all go to plan. ive to do the main work ie wirring and pipes off the ramp but the initiall change over can be done on the ramp which isint to bad
gareth
in that case then it'll almost be a doddle
jamesh1977
- BEWARE Zone Thief
hopefully all will go to plan and be as easy as hoped
