camber
bri_on_1
Hi all, this is my first post! i have a 325i se and it has been lowerd 60mm
i think it is too low as i am eating tyres. I am thinking of putting 35mm springs on instead ie raising it by 25mm will this change the camber on the rear wheels so i can get more life out of my tyres.
ps. i am chuffed i found this site it looks very helpfull :O)
thanks
bri_on_1
thanks
bri_on_1
kam-325i
Hello and welcome..
It will reduce the amount of camber......
Welcome to the zone on behalf of the team!
I agree 60mm drop is too much - it'll handle much better on the 35mms if they are good ones.
There are genuine BMW rear suspension bushes available to help reduce the rear negative camber. Being discussed in a current thread.
bri_on_1
Thanks Kam, that is good news as this is costing me a fortune in rear tyres at the moment. the car is so low that i have trouble even getting my trolly jack under it.
kam-325i
i have them same problem with mine. i have to lift the car up before i get the trolley jack under it.
bri_on_1
I have got to be honest and say i am fed up with hitting the scorpian system on drain covers and baby rabbits heads ectkam-325i wrote:i have them same problem with mine. i have to lift the car up before i get the trolley jack under it.
i also have a clonking sound from the front end and i was told by a mechanic if i raise the hight ie the springs it will solve the clonking out. I am not sure what the clonking sound is but i am sure you lot will be abel to tell me what it is :O)
Front end clonking could be many things - suspension ball joint, dampers bottoming out, steering rack, anti roll bar drop link, anti roll bar mount, exhaust hitting, etc., etc.
You have to get under there and see.
bri_on_1
I will get under her tommorow and take a look :O) thanks for the help i am sure you will see many more questions from me on here
kam-325i
Mines lowered 60/40 with a scorpion system aswell.....and mine aint that bad...
But i am going to replace the scorpion back box as it to heavy.
MJG
The only front end knocking that would be solved by raising the car, is the clonking of the car on the floor.
Lower it more and just get cheaper tyres
ed325i
09 SET RUBBER MOUNTING ECCENTRIC D=30MM 2 33329058822 $59.99There are genuine BMW rear suspension bushes available
bri_on_1, could you shrink that avatar down a little, please - it's pushing the text off the side of the page.
bri_on_1
sorry m8 i will have agoBrianmoooore wrote:bri_on_1, could you shrink that avatar down a little, please - it's pushing the text off the side of the page.
Perfect - wish I knew how to do things like that!bri_on_1 wrote:sorry m8 i will have agoBrianmoooore wrote:bri_on_1, could you shrink that avatar down a little, please - it's pushing the text off the side of the page.
bri_on_1
its defo not the sump! this only happens on a bad road full of pot holes and drain covers ext but on a flat road its fine. It sounds like metal to metal i think it has something to do with the anti roll bar or the steering rack. I can just about remember the mechanic saying that the car is so low you can only just fit a fag paper between them? but i did not take any notice as i had just bought the car and wanted to go for a spin in my new rideBilly_Blue wrote:have a look at the sump, see if its that that hitting ground and making the nockin noise
MJG
It sounds like it could be the sump then dude.
There is no mechanical parts which should collide when lowered. Not looked under e36 to see ARB and steering rack but I would have thought the ARB was on the back and the steering rack is on the front right up against the crossmember
maxfield
its an old car the bushes wear down meaning metal hitting metalMJG wrote:It sounds like it could be the sump then dude.
bri_on_1
There is no marks on my sump, the clonking sound is defo from the front end i sumtimes get a clonk on the front right then the front left? the suspension has never bottomed out on this car yet! i am looking at an invoice from the last owner and found that he replaced the front lower arms x 2 £80 and 2 x bushes £18 maybe they need replacing again? I will try and get under the car tommorow but the car realy needs to go up on ramps to have a good look.
kam-325i
how long ago was they replaced ?
bri_on_1
16/04/2005
kam-325i
Not that long ago then.....
bri_on_1
i havent had the time to have a look today but i took a pic to show you how low she is
http://www.putfile.com/pic.php?img=4382186
gareth
looks nice mate!
nice colour
i've found lowering does put an odd angle on the antiroll bar drop links and if they're fudged, they can give up.
it's not arch scraping with the big rims is it?
kam-325i
What size wheels have you got....?
Mine dont look that bad at the back
bri_on_1
The wheels are made by ACE and they are 17`s i have posted pics in the galery and talked about wheele spacers ect to sort the camber out!
gareth
wheel spacers won't change the camber...
