What is torque?
chinchilla
Post Sat Dec 30, 2006 11:43 am
can some one define torque for me please
Gortour
Post Sat Dec 30, 2006 12:00 pm
It's what a woman does too much of... winkeye
Very roughly its how hard the engine can pull.
I saw something recently on here that says BHP is how fast you HIT the wall, Torque is how far you DRAG the wall...
Driving up a steep hill or towing something heavy, the more torque the car has the less it notices the extra weight.
Power is how fast it can go, torque is what it can do under load...
Hope this helps.
Post Sat Dec 30, 2006 12:01 pm
torque is how hard u hit the wall, HP is how fast u hit the wall get me?!
fuzzy
He who sleeps with "Gingers"
Post Sat Dec 30, 2006 12:02 pm
in plain english that even a joiner can understand..... winkeye i asked this before but didnt understand most of the replies,might as well of been in a foreign language :mad:
fuzzy
Post Sat Dec 30, 2006 12:06 pm
gortour wrote: Power is how fast it can go, torque is what it can do under load...
Hope this helps.
thats the best and simplest way ive seen it described. :wink:
wildeian
Post Sat Dec 30, 2006 12:15 pm
Torque is the turning force about a pivot
What that means is if you imagine see-saw, the pivot is in the middle. The torque is the person (force) sat on the end forcing the see-saw down.
Now relating it to a car:
If you imagine that the pivot is the centre of a wheel, the torque is the force turning the wheel felt at the tyre.
Torque is made up from the distance from the pivot (metres), multiplied by the force (Newtons), giving a value in Newton-metres (Nm)
Templ8e30
Post Sat Dec 30, 2006 12:22 pm
Torque is turning force, basicly.
Eg, the tighter you do up a bolt the more torque you've applied to it.
Power is the rate at which the torque is applied.
Cheers,
Iain T
2007 Mazda 6 2.0 estate
reggid
Post Sat Dec 30, 2006 1:28 pm
Torque = Force x perpendicular moment arm
in terms of cars torque is the twisting force on the drivetrain caused by the pistons applying a force onto the crankshaft (which has a moment arm called the crank throw).
When you feel acceleration as you travel in a car you feel the torque characteristics of the engine (torque curve), power is neccessary for motion (speed) and is why power is a good measure of performance potential as it combines torque and speed (i.e acceleration and speed)
Jon_Bmw
Dangerous when thinking
Post Sat Dec 30, 2006 2:46 pm
Wheres the tigger with a wikipedia quote? :D
