M20 Intake manifold mod....
kam-325i
Post Fri Dec 29, 2006 8:42 pm
I have been thinking about this for a long time as fabrication, for me, would be no problem....
Would there be any benfit in modding the intake manifold ?
This is what i am thinking about. Chopping of the bits that bolt to the head, about 30mm or so behind the injectors, welding them to, say, 120mm X 120mm Ali box section, and then fixing the TB to the centre of the box section, or using two smaller TB's. ?
I know that BMW would of spent loads on the design of the intake manifold, but it just looks so clumsy.....
Post Fri Dec 29, 2006 8:50 pm
120mm box section sounds a bit big? :?
kam-325i
Post Fri Dec 29, 2006 8:52 pm
Ive got access to any size from 40mm X 40mm upwards, in 5mm increments, upto 200mm X 200mm. Some Rectanlge.
Andy335Touring
Post Fri Dec 29, 2006 10:05 pm
How would you radius the runners where they join the plenum(box section) ?
Could be good for some folks who want a bigger TB for a bit of extra air flow ?
Have a look on ebay.com for some cheap large TB's ?
http://motors.search.ebay.com/throttle- ... eNameZWD8B
kam-325i
Post Fri Dec 29, 2006 10:20 pm
Radius the what ?????
Like the "Trumpets" on a M3 plenum ?
I can spin some Ali tube to make them.
Andy335Touring
Post Fri Dec 29, 2006 10:28 pm
Trumpets if practicle but i was thinking just rounding the edges off so the air doesn't have to go over a sharp edge as it travels from the plenum into the runners ?
A bit like i've done on here, just round the edges off.
