door mirrors - brilliant - 318is
tigerbill
hello, the only 'bad' part of my car is the door mirrors -they seem to have faded anf there is corrosion on the metal part - is the normal thing to get them sprayed or is there a stoc of NOS mirrors somewhere?
kevin316i
This is the case with virtually all E30 mirrors. The easiest thing to do would be to rub down the metal section to remove all corrosion and apply etch primer before respraying. If the plastic housing is flat paint (e.g. white/red) you could try T-Cut followed by a good waxing. Metallic shouldn't have faded unless something happened to the lacquer coat. It is easy to get touch up aerosols from the BMW main dealers which are a good colour match but expensive. Alternatively you could get paint mixed in an autofactors and loaded into aerosol.
ian332isport
I'm guess in that NOS means New Old Stock ?tigerbill wrote:is there a stoc of NOS mirrors somewhere?
If so, then you can still get them from the dealer. Infact, you can get virtually everything for an E30 from the dealer still.
Ian.
tigerbill
thank you for your replies
reddevil
Put a post in the wanted section, the old ones just unbolt, find out your body color from the front suspension turret, one of the guys will have some laying about, don't forget some are electric, some are not.
Red D
Red D
1991 (H) 318iS Diamond Black, M-tech II spoiler.
K&N Panel filter-Viper2 chip-Zone BBTB
XBOX LIVE - reddevil1976
