car pulls to the left, tracking?
bigmattpowell
Had the tracking looked at some time ago as car was pulling hard left, he said control arm bushes were shot so no point. Replaced with powerflex eccentric, still pulling so had it looked again. This guy said it was 5mm out but he couldn't correct it as it was seized and thus may need new trackrod end(he tried heat etc.) . Is 5mm enough for it to pull hard? When I release the wheel it immediately flicks left even at slow speed. Checked tyre pressure etc. And shouldn't a decent garage be able to adjust it even if it's never been touched in 15 years!
DORAS
5mm is definatly enough to cause you a problem!
I had the same problem, this is in order of doing the cheapest things first.
first you need to free off those track rod ends, i had the same problem i used a heat torch (plumbers gas torch) and rust off spray then a lot of brute force with molegrips and a spanners. once there moving keep working them in and out adding lots of copper slip so it doesn't happen again.
Then get the tracking done. If it is still out after that try swapping your wheels front to rear as the front tyres will probably be out of shape due to your problem (made a huge difference on mine) dont leave them that way around its just for trial purposes.
if youve done the bushes and its still doing it then you probably have a bent front wishbone (like mine) or at worst the cars been smacked up and not repaired properly on a jig.
Rich
Rich
bigmattpowell
Cheers for that, part of the problem is i'm waiting for my BBS to be refurbed and got some new tyres waiting so while i've got on my bottletops with shite tyres, it's not worth the effort of moving them round. Think i'll find a garage with the grunt to loosen and track it and take it from there.
