hello
can anyone help my cars running eratic does not tick over properly total loss of power sounds almost as if its missing.
sick 318i s
kam-325i
Have you checked to see if it is miss firing ?
sphillips
yeah is there anything else you can think of???
kam-325i
Yeah....Loads.......
Leaky air intake system, poor fuel pressure, Clogged injectors, low compression, ECU on its last legs, Head gasket knackerd........
Did this problem start all-of-a-sudden type thing or has it been getting worse ?
sphillips
it has got a brand new air flow meter on it. The problem just started.
In that case, check that it's plugged in properly, and check the big rubber hose to the throttle body for splits and cracks.sphillips wrote:it has got a brand new air flow meter on it. The problem just started.
Demlotcrew
And make sure its for a non cat car or for a cat car if yours has one.
Andrew
Andrew
sphillips
Thank you very much chaps for your advice. Ill check for these problems tomorrow and ill let you know how i get on
