front fogs not working
spook
- League two here we come !!!
fitted new relays, fuses, bulbs, and still no joy, any ideas?, back ones are fine, cheers spook
Gortour
Sorry if this is a stupid question, you have fitted the two-button switch as well?
They won't work with the rears on the single button switch.
Gortour
Also the foglight relays are different to all the rest.
Try swapping the front and rear relays over and see if the fronts then work
spook
i have the 2 button switch,and both relays are new and slightly different in the pin layout
Gortour
If the rear fogs work, try swapping the relays over...
Possible one of your relays is dodgy
spook
gordon, these two relays are sat side by side are they
Gortour
They are indeed Spook. Black ones in my Touring. On the end nearest the wing.
Another thought, you don't have your high beams on do you? Have heard of some BMs that turn the fogs off with high beam as the guys at BMW decided you wouldn't want both... Mine doesn't but yours is pre-facelift isn't it?
Gortour
Sorry Spook, my mistake, yours is post facelift like mine, so the high beam shouldn't affect it.
Certainly try swapping the relays over though. They can stick
spook
thats bizzare, i re fitted the old relays and hey presto everthing works, with the new relays i was either getting just headlights and no fogs and vis versa, and ive just got some smoked hellas but they can wait, cheers gord
on ps its a facelift model but only just
Gortour
No problems mate.
Hopefully catch up in Jan at the meet.
Take it easy.
Take it easy.
jcjdavis1
I had prob when I fitted mine,cure was plugs in back were not in properly.simple I know but worth a check.
FlashBastd
Hey JCJ, I am fitting front fogs to mine soon, I reckon I have most of the bits, but did you have any probs removing the blanks / fitting the fogs?
Sorry to hijack!
Sorry to hijack!
1993 E30 318i Lux Auto Touring - SOLD
2001 Ford Mondeo 2.5 Zetec-S 5dr - SOLD
2004 Lexus IS300 Limited Edition Auto - SOLD
2005 Honda CR-V 2.0i Executive Auto
2001 Ford Puma 1.7i Black
Gortour
You'll need fixing screws (less than £10 from the stealers)
Plastic blanks just clip out. Take the retainer clips for them out too.
You'll need to screw the lamps in, and find the plugs - up behind the headlight rear covers
Fit the relay in the fuse board and fit the two fuses.
Change the fog light switch for a twin button, and job done. Took me about half hour.
And a bulb for the cluster, which is probably the longest job of the lot.gortour wrote:You'll need fixing screws (less than £10 from the stealers)
FlashBastd
Nice one, ordered the screws and inserts, fitted the 2 button, relay is sat in the glovebox.
What are the fuses? Size / position? Also any idea what the bulb is?
Finally, what bulbs do the fogs take?
Fuses are 29 and 30, both 7.5 amp. Bulbs are 55W H3. Instrument panel bulb is the same twist in type as most of the other warning lamps.
Gortour
Mine had the dash bulb fitted already when I put my fogs in... Is this unusual Brian?
Should light up green to the left of the orange one for the rears on the dash.
FlashBastd
Thanks guys. Mine "might" have the bulb then? Fingers crossed!
As these are used lamps, I was thinking that I might as well replace the bulbs prior to fitting. I need to get some more fuses anyway, so a trip to Halfords / some motor factor is probably in order
FlashBastd
What are the main beam and dip beam bulbs?
jcjdavis1
Hi both headlamp bulbs are H.1 ,you will find a book on the shelf in halfords that tells correct bulb sizes
FlashBastd
thanks!
FlashBastd
Despite mine being very similar to Gordon's, mine didn't have the bulb, got them in and sorted inside around an hour on Monday morning. Only took so long as the weather was awful.
