can some one please help
i am looking at some 8x18 inch wheels in 4 stud to put onto my car....can you tell me whether they will fit properly and whether or not i will have any problems with them????
wheels help
kevin316i
I have seen some E30s in magazines with 18" rims, but you would probably need to get wheelarch lips rolled to accommodate them. They would also have a bad effect on your cars handling, lots of tramlining I would think. E30s were never designed for such large diameter wheels.
maxfield
4/100??
they will fit may need spacers depending on offset
but should be ok
but should be ok
orangecurry
original Alpina wheels were 8J, at the back anyway, so as long as the offset is correct, you can fit 225 tyres (with a suitable profile) and you shouldn't have any rubbing issues (not sure about the front though) - wheel diameter has nothing to do with rubbing.
So as The Max said, if the PCD and offset are correct AND the hole in the wheel-centre is large enough (where the hub sits), they will fit.
However the handling and ride WILL be shite - and if you hit a pothole with low profile tyres on 'cheap' aftermarket rims, they WILL buckle - but that's your call.
orangecurry
iil325i
any good 18" wheel will be ok, my mates have had 18" wheels on there cars for years and not had any probs with them, and unless you are going to track your car i dont think you will see any dif in handling.
and if the bobe size is to big you can get a thing to go in there to make it fit
any good wheels shop will sort you out with the right wheel
and player 6 got 19s on his e30 with no nmods or rubbing and i think its lowered 80mm
