Leak in car? Any common places?
OBs
Post Wed Dec 27, 2006 9:42 pm
I have just brought my first E30 on Chrimbo eve :woohoo:
Its got a leak somewhere :x but I havent ripped it apart just yet to investigate, I found the passanger side door was not shuting properly at the very top of the frame so I fixed that which could of been one or the reason, But... Is there any places like the bulk head etc that tend to let water in... I havent got a sunroof either.
Any help would be much appreciated! :thumb:
Nelly
Gumbo
Gumbo
Post Wed Dec 27, 2006 9:48 pm
Check the rubber gromit in the bulkhead where the loom from the fusebox comes through, also check the scuttle panel in the corner where the wing meets the scuttle.
Then check around the area of the wiper motor - located under the plastic trim, passager side - scuttle panel :wink:
Ooo - not forgetting the windscreen rubber and door seal :mad:
Neil.
"I F**KING LOVE YOU GUMBO"
OBs
Post Wed Dec 27, 2006 9:53 pm
Cheers Neil! :mad: I will add that to my check list :thumb:
Its either that or I just buy some Gold fish and make a little water feature? Maybe a first!! winkeye
Cloggy Saint
Post Wed Dec 27, 2006 10:13 pm
Heater matrix is also a fairly common cause of leaks.
OBs
Post Wed Dec 27, 2006 10:15 pm
Another one for the list then!!! :roll:
Is the carpet wet on top or underneath? E30 carpets are waterproof.(ish)
OBs
Post Wed Dec 27, 2006 10:18 pm
I dont know really Brian? I would say on top as it actually has tide marks!! :eek:
Ill go out and check!!
OBs
Post Wed Dec 27, 2006 10:29 pm
I have checked I think its a mixture of both Brian? More so on the passager side? I got my hand under the seat and pushed it through the joint in the carpet towards the back I was 'Damp' but the under dash area is more wet (on top) Havent checked under yet..... :x
Post Wed Dec 27, 2006 10:30 pm
If it's on top, and has tide marks, it suggests it may be coolant, so keep an eye on the level in the header tank.
Take off the panel above the glovebox, and then the one to the right. You will then be able to see the elecric heater valve, which is a common leak source.
Post Wed Dec 27, 2006 10:34 pm
Plenty of other places a neglected E30 can leak water into the interior, but they're all fixable, within reason.
Worst one is rust around the big rubber grommet at the back of the glovebox where the wiring comes down from the fusebox. You'll be able to examine this area with the glovebox top panel off as well.
OBs
Post Wed Dec 27, 2006 10:35 pm
OK thanks for that, I will do it as soon as possible, Thanks again :wink:
oguz327
Captain Armco
Captain Armco
Post Thu Dec 28, 2006 12:59 am
Congrats on the new purchase!
If you can get the carpet out as a last resort (brace your self) and have a good look for rust and holes, it wasn't until i removed my carpet that i saw a few suspect problem area's that would never have been spotted with the carpet in.
Check for blocked sunroof drains also.
jamie325isport
Post Thu Dec 28, 2006 1:14 am
I had a water leak in my old 323i sport. First thought it was heater matrix (are you losing coolant?). Then i found that the box section under the battery tray, in the drivers front wheels arch was rotten so there was a hole to the bulk head (repaired that). Still had a leak so dash came out and that was when i found the problem. Just under the bottom corners of the front screen there is a lump bit of the bulkhead that runs along the bottom of the screen. Well that had serious rust in the corners major nightmare. Hope you dont find anything like that. Good luck water is a pain gets everywhere.
Wanted:- One Genuine 7J Alpina. PM me
oguz327
Captain Armco
Captain Armco
Post Thu Dec 28, 2006 1:19 am
Basically, check everything. E30s seem to love bathing :x
OBs
Post Thu Dec 28, 2006 11:36 am
oguz3001 wrote:Basically, check everything. E30s seem to love bathing :x
Ok! Im on the case (No sunroof though) but will check all the rest! Thanks for all your advice guys :thumb:
iil325i
Post Thu Dec 28, 2006 12:03 pm
i had a water coming in from under the drain hole in the bolkhead, as in where the water goes from where the wipper motor sits. i found it by poring water over the car and and seeing where was getting wet, you will need to remove as much or the interoir as poss i just pulled back the carpet and took the seats out. took me about 10 mins to find. i would say dry up whats in there 1st if you can as if its uder the seat as well, sounds like the door hasnt been shut or something silly. thats the other place is the door, take the card off ad see if the holes in the bottom have shit in them, and test the door by putting water on it as well.
good luck
lee
Ritz
Post Thu Dec 28, 2006 12:55 pm
Might want to check the boot, dig around under the carpet everywhere. I found a rust patch waiting to creating a hole underneath the plastic holder for the first aid kit. Also check the corner where the jack is kept, make sure its dry.
mrLEE30
Post Thu Dec 28, 2006 1:04 pm
also check your sill drain holes are not blocked with crud, examine underneath and there are several holes to let water out of the sill, if these block up and your sill is full of water, it will leak into the cabin. (but a full sill is normally accompanied by a sloshing noise when driving)
mrlee
drewjak
Post Thu Dec 28, 2006 5:54 pm
strangely enough, mine was leaking where the glove box bolts to the bulk head above passengers feet, i only discoverd this because my glove box wobbled about,and when i came to fix it 1 of the threads for the bracket had completely rotted off and was allowing water to seep in, on further investigation i found that the n/s wing had no sealer on it(by the fuses) and was guiding the water on to the bulk head instead of running along the top of the wing and down to the front.
DemonDaz
Post Thu Dec 28, 2006 7:07 pm
Mine used to leak from the roof box at the back for the convertible hood.
It leaks into there, there should be drain holes but these become blocked. the box fills with water at the sides, and then splashes over wheel arches into the interior. should be another thread on this in technical help, started by me. check these drain holes anyway otherwise may cause you trouble later.
ucpsale
Post Fri Dec 29, 2006 12:24 am
Hello, inside the engine bay fixed to the bulkhead is a black rubber drain hose, make sure that this is not blocked with dirt. Thankyou
OBs
Post Fri Dec 29, 2006 7:46 am
Thanks for all the help...
I was going to make a early start on searching today but have now woke up and relised the sky seems to be leaking :cursin:
Also : DemonDaz says about leaking convertable box? So does mine still have that area that he was on about... Where?
DemonDaz
Post Fri Dec 29, 2006 9:31 am
Doh, Wrong thread, I thought you had a cab for some reason! :o:
OBs
Post Sat Dec 30, 2006 3:07 pm
ucpsale wrote:Hello, inside the engine bay fixed to the bulkhead is a black rubber drain hose, make sure that this is not blocked with dirt. Thankyou
Where abouts is it, Please?
Right Ive got the glove box out and all surrounding bits and bobs and also loosened the wiring loom away from the body etc... Bingo! The gromet is leaking :roll: So thanks for that info!
Also the battery box area has alot of water in it should that have a drain hole somewhere?
Just about to check the heater box area and wiper one too...
OBs
Post Sat Dec 30, 2006 4:41 pm
drewjak wrote:strangely enough, mine was leaking where the glove box bolts to the bulk head above passengers feet, i only discoverd this because my glove box wobbled about,and when i came to fix it 1 of the threads for the bracket had completely rotted off and was allowing water to seep in, on further investigation i found that the n/s wing had no sealer on it(by the fuses) and was guiding the water on to the bulk head instead of running along the top of the wing and down to the front.
This weeks winner Drewjak! Exactly the same problem here to, it rusted the bolt from behind... To claim your prize just phone this number : 09703...... and pick from a long list of gifts winkeye Premiam rates do apply.
Problem hopefully solved.
