wheel fitment?
SilverShadow
Hartge Crew
Post Wed Dec 27, 2006 3:18 pm
Guys im considering in buying some wheels that have been offered to me. However the guy selling them has only given the following info:
7,5Jx17H2E25 36270775 The pitch diameter is 4/100?
question is, will this fitment of wheel fit my E30? will i need spacers?
ian332isport
Post Wed Dec 27, 2006 3:45 pm
Those should fit straight on without spacers.
They are 7.5 x 17" with a 25mm offset. 4/100 is the correct stud pattern for an E30.
The only thing that could be wrong is the centre bore size. It needs to be 57mm (57.1mm if you want to be really anal). If this is not correct, the wheels will not be held central on the hubs and you WILL get vibration/wheel wobble.
Ian.
SilverShadow
Hartge Crew
Post Wed Dec 27, 2006 5:37 pm
thanks for that ian!
