black kidney grille?
snoops
Major Helmet
Post Thu Dec 21, 2006 7:11 pm
this might sound stupid but to get a black kidney grille can i just spray it black?or will it not come out good?
Barnz
Guildford Geezer
Post Thu Dec 21, 2006 7:15 pm
Correct me if wrong but if you sand the thing down to get the shine off the chrome, then black paint should stick nicely..... thinking of doing that to mine too, so let me know how you get on bud. :P
E34 525tds - on the way to replace 325i
E30 / 34 spares
bigmattpowell
Post Thu Dec 21, 2006 7:17 pm
Apparently it works fine but it just may not match the side grilles any more. Get a whole spare set of front grilles and spray it all together. And lots of coats
Barnz
Guildford Geezer
Post Thu Dec 21, 2006 7:18 pm
bigmattpowell wrote:Apparently it works fine but it just may not match the side grilles any more. Get a whole spare set of front grilles and spray it all together. And lots of coats
Good idea mate, thanks.
E30 / 34 spares
Barnz
Guildford Geezer
Post Thu Dec 21, 2006 7:19 pm
Go for it Snoops!
E30 / 34 spares
Pal318is
Post Thu Dec 21, 2006 7:22 pm
Never thought about doing all three bits..that is a stupendous idea 8)
Pal
Image[img]http://Image
fuzzy
He who sleeps with "Gingers"
Post Thu Dec 21, 2006 7:35 pm
i rubbed down all 3 bits with fine wet and dry sandpaper to give the paint a good key and sprayed them with black satin paint.that was a couple of months ago and its still in good condition
d6dph
Post Thu Dec 21, 2006 7:38 pm
I keyed the kidney, used plastic primer then satin black paint. has been fine for about 8 months of abuse. Plastic primer will flex when stones hit it so shouldn't chip.
I didn't spray the side sections, but I did give them a good coat of Autoglym bumper gel, brilliant stuff for matt black trim, I only used this as that's all I had in the garage at the time.
snoops
Major Helmet
Post Thu Dec 21, 2006 9:31 pm
ye i myt do that but my mate might be sellin the complete grill set with eyebrows, how much do you think i should pay him?
Cotty
Hartge Crew
Post Thu Dec 21, 2006 10:11 pm
Love the black grill :twisted:
timmyboy
Post Fri Dec 22, 2006 12:43 am
im just about ready to paint these now should be fun winkeye
(00=[ll]=00)
Image<embed></embed>
mac325i
Post Sat Dec 23, 2006 8:03 am
Beat you to it :lol:
timmyboy
Post Sat Dec 23, 2006 11:21 am
good work!!!! :D
(00=[ll]=00)
GDBN
Post Sat Dec 23, 2006 11:16 pm
Easier just to buy a black covers. Then if you don't like it you can take it off.
G
325bhpbruiser
Post Sun Dec 24, 2006 6:35 pm
just take all 3 off, a good sugarsoap down, rinse, dry, dusting or plastic primer then satin.
only thing to check is no moisture sitting off in the corners of the grill when painting. this way all 3 grills will match mate!
mull3tt
Post Fri Jan 12, 2007 5:46 pm
timmyboy wrote:good work!!!! :D
Might be a stuped question but where does the high beam go??
And where do u get these single light grille parts? They make it look mean
noney82
Post Fri Jan 12, 2007 5:56 pm
they look so much better with only one ligh per side, can this be done or has it been photoshopped
timmyboy
Post Sat Jan 13, 2007 1:27 am
made the grilles out of two standard ones, there is a pic up the page. sprayed them black, the yellow lights are a photo chop to see if they looked good or not, the lights to use are mk2 polo lights, same size as the e30 and include the high beam.
(00=[ll]=00)
Pal318is
Post Sat Jan 13, 2007 2:35 am
They look mean for sure...I personally like the yellow lights too..
Good Stuff
Pal
Pal
goosiegander
Zonegoose
Post Sat Jan 13, 2007 3:09 am
Been there and glad, just took the job lot off rubbed it all down and resprayed within about 2 hours...
Teaching myself bodywork and spraying, will try and put some pics up for a laugh on a seperate post, Spraying the lot is the way to go! :)
E3OSAM
Post Sat Jan 13, 2007 2:47 pm
should get a carbon grill they look mint and are slightly more orginal, i did have a painted one but thought carbon was better
OLD SKOOL
noney82
Post Sat Jan 13, 2007 6:05 pm
timmyboy how did you make these grills from standard ones i think they look the bees
d6dph
Post Sat Jan 13, 2007 7:29 pm
E3OSAM wrote:should get a carbon grill they look mint and are slightly more orginal, i did have a painted one but thought carbon was better
Real carbon or carbon look?
