E30 M3 3.2 OR 3.0???
b4bmm
I dont know alot about putting the E36 M3 engine
into the E30 M3. Is there many cars on this site with this lump
transplanted?
What are the pros and cons and costs of doing this conversion:
Is it difficult to maintain i.e work on the engine?
How long should the conversion take by a qualified technician?
How much would the handling of the car be effected?
How fast will the car actually be compared to the s14?
I feel the 215bhp s14 engine just cant cut it anymore with this power output. Would it be better to turbo this engine than do a transplant to keep the cars handling characteristics or would this drastically effect the reliability? Is there another engine more suited than the s50/s52?
Reliablitly, speed and cost are big factors for me.
All comments appreciated.
transplanted?
pete69zx
Gouki
i'd personally sell the car as it is and buy a standard 2 door, fit the engine in get it running. You'll find it hard to sell the M3 on without the original engine plus they come as LHD may counter problems unless the lump u get is from a LHD car. Make more economic sense as you'll get a lot of cash for your M3 which could be used for other things like an M3 rep bodykit for example?
fuzzy
in my opinion if you have an m3 already id probably keep what i have and turbo it if your looking for more power.my conversion was quoted at 2 weeks max but ended up taking 17 weeks so thats a how long is a piece of string question and cost for a full transplant will run into several thousand pounds,possibly reaching as much as £6000 for what would only be a modest 70 odd bhp increase,then you will go the turbo route anyway.cheapest and easiest to upgrade in future is the turbo route imo but would probably still cost £2000-£3000+ if using what youve already got. the list of pros and cons will be purely down to peoples opinion .
pete69zx
Just my 2 peneth here...
If you choose to Turbo an engine that was not originally designed to be turbo'd, then you can end up spending big money.
If you choose to use another engine that is none Turbo from the BMW family, i.e... e36 m3 engine, then you have all the reliability that BMW are famous for, plus.... no Turbo lag aswell
fuzzy
thats a good point i didnt consider,buy a lesser model and start from there or if possible try to buy an m3 with blown engine and use that as a base if youd prefer to keep the m3 shape.i think ripping the original engine out of your m3 for a tranplant would have you hung drawn and quartered in some partsGouki wrote:i'd personally sell the car as it is and buy a standard 2 door, fit the engine in get it running. You'll find it hard to sell the M3 on without the original engine plus they come as LHD may counter problems unless the lump u get is from a LHD car. Make more economic sense as you'll get a lot of cash for your M3 which could be used for other things like an M3 rep bodykit for example?
pete69zx
Agree'd!fuzzy wrote:thats a good point i didnt consider,buy a lesser model and start from there or if possible try to buy an m3 with blown engine and use that as a base if youd prefer to keep the m3 shape.i think ripping the original engine out of your m3 for a tranplant would have you hung drawn and quartered in some partsGouki wrote:i'd personally sell the car as it is and buy a standard 2 door, fit the engine in get it running. You'll find it hard to sell the M3 on without the original engine plus they come as LHD may counter problems unless the lump u get is from a LHD car. Make more economic sense as you'll get a lot of cash for your M3 which could be used for other things like an M3 rep bodykit for example?
fuzzy
hell man, it was months before i could walk the streets safely after i put a ford engine in mine ,and that was me just using a 325 touring
i always thought that turboing a non turbo engine would lead to reliability problems but most on here say that isnt the case and turbo lag isnt really a problem either as when i upgraded my turbo they recommended a smaller .48 exhaust side to allow it to spin up quicker,my boost comes in at about 1400rpm
b4bmm
I think i would be heading towards a modified s14 route as opposed to a transplant.
What options would i have as regards this(naturally aspirated)?
Rosc0PColtrane
There's a guy called Henry on here with a e30 m3 with e36 m3 lump in it. Immaculate. If you search my name in the picture and vids from meets section, you'll see pics of it and engine. You'll need to keep the e36 clocks and diagnostic socket.
buster
you dont need the e36 clocks,i used e30 m3 ones.
215m3
real this websiteb4bmm wrote:I think i would be heading towards a modified s14 route as opposed to a transplant.
www.board.s14power.com
I am going to be adding a turbo to my S14 race car when i have goot my business up and running. www.bmbits.co.uk in the new year.
The head is excellent for tuboing as the exhaust ports are wider/larger than the cosworth head. The crank and rods are strong enough. Change the pistons to JE's at $650 for 4 or use a decomp head gasket $135. Sell you head as it's worth about £800 and buy a 195 head at £500. You only need the standard 248 cams. 10 a penny and sell you 48TB's(£500+) and get 46's £100. The turbo i'm going for is a GT3076R and at 13 psi am looing at 460 bhp approx. Mapped to an emerald replacement ecu system. Dave walker already maps one of these engines with said HP results.
Don't put a 6 cylinder engine in as this has been known to effect the handling, otherwise buy another 2 dr model and sell the M3.
Good luck whatecer you decide to do.
check out www.s14.net in best ongoing threads as there is one about turboing the S14 on there
jmc330i
Using a LHD E36 M3 engine actually makes the conversion into a RHD E30 easier as far as the wiring is concerned - assuming the ECU of the E30 M3 is on the same side of the car as the RHD E30s then it will also be easier. Exhaust manifold/steering clearance issues would also be gone.Gouki wrote:You'll find it hard to sell the M3 on without the original engine plus they come as LHD may counter problems unless the lump u get is from a LHD car.
After doing my 3.0ltr conversion (into a RHD 325i Sport, which is almost finished) I am seriously considering using an E30 M3 or normal LHD shell for my next project. It would be mainly a track car, but I see no problems for everyday use.
You need to decide what you want the car for. The way I look at it, an S50 powered E30 M3 would be a fast car, comfortable for crusing and embarrass some much newer machinery. Whether the 6cyl affects handling or not, I have no idea - you will always get differing opinions on that subject, but BMW put the S14 in for a reason.
An S14 turbo would also be a fast car and I suspect it would be a serious track weapon - handling could be as close to what BMW intended, with the extra power youre after. If the turbo install was done correctly, I also suspect that it could be decent everyday car as well as a bit of an animal
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
b4bmm
Thanks for the help 215m3. So how much do you work out the total cost?
There is alot of good information on those other sites too
215m3
turbo $1200b4bmm wrote:Thanks for the help 215m3. So how much do you work out the total cost?
pistons £650
head bolts $145
wastegate $225
BOV £75
comp head £135
Manifold £700
emerald ecu?
not looked into intercoolers and associated pipework yet.
exhaust, i have removed my fuel tank and am getting a fuel cell. I plan to use the space left by the fuel tank to split the exhaust has have two exhauts, one out each side infront of the rear tyres. price £300 ish
My car already have bbk up front, but am converting the back to 4 pots and grp N coilovers all round.
For the power output it's far better than the s50 etc. I plan to build the engine myself.
M5pilot
Excellent advice.Gouki wrote:i'd personally sell the car as it is and buy a standard 2 door, fit the engine in get it running. You'll find it hard to sell the M3 on without the original engine plus they come as LHD may counter problems unless the lump u get is from a LHD car. Make more economic sense as you'll get a lot of cash for your M3 which could be used for other things like an M3 rep bodykit for example?
215m3
With regards to building an s50 engined e30, but not using the M3, the brakes, suspension and handling are inferior, meaning you would need to spend money to upgrade to 5 bolt and possibly rear discs. Though you may feel you would want to upgrade these items on the M3, but you would get more money if sold on. The brakes would deifinatley need upgrading.
M3 replica kits, in my eyes are just ugly, especially around the rear window rake.
If you M3 is in every good condition body wise with about 100k miles on it i would either sell it and find another in a slightly rougher condition or get a normal e30
iil325i
i was on about putting a 6pot in my e30 m3, and i was getting get put a rep kit on a norm e30 and it will kil the handling, but i think a m3 kit would just look silly and all you would get is " thats not a real m3" and i was talking to people who have e30 m3s with 6 pots and they said as long as you set everything up right and play around with stuff it will be ok.
i think if you went for the 3.0 m3 lump you could sell you lump and bits and that would pay for most of it.
but if you have the money, i would say go 3.2 as if your going to do it do it right,
i also think it would sell, as there is more and more of these being done, i would love to have one
have a look see here
http://www.s14.net/forums/showthread.ph ... adid=18118
maxfield
if you want to tune the engine n/a it will go into big bucks but it's certainly worth it.
Nice set of cams
Carbon fibre airbox
Alpha-N (EMS)
50/50 header with supersprint exhaust
Next stage.
Head work.
Bigger valves.
Even further.
High comp 95mm pistons.
Evo sport crank.
Or if you wanted to stay 2.3 high comp 93mm pistons.
But if you did go turbo you should certainly lower the compression.
PS. www.e30shop.de Look on here for prices but be sat down
Nice set of cams
Carbon fibre airbox
Alpha-N (EMS)
Next stage.
Head work.
Bigger valves.
Even further.
Evo sport crank.
If you have an engine with EWS then you do need to keep the E36 clocks - but not neccessarily connected up and in the car.buster wrote:you dont need the e36 clocks,i used e30 m3 ones.
If the car ever needs to be connected to the BMW diagnostic computer, the computer will look for the E36 cluster and refuse to proceed if it can't see them.
billgatese30
don't you mean you need th e36 clocks if you have ews??Brianmoooore wrote:If you have an engine with EWS then you do need to keep the E30 clocks - but not neccessarily connected up and in the car.buster wrote:you dont need the e36 clocks,i used e30 m3 ones.
buster
i have ews and i am using e30 clocks !
True about the diagnostics though
To clarify a bit, since I messed up an earlier reply, the E30 clocks will work fine if you have an EWS engine, but if at any time your engine needs to be connected to the BMW computer (e.g. EWS recoding), then you will have to temporarily hook in a set of E36 clocks.
