Poly windows
northloop
Post Fri Dec 22, 2006 12:24 pm
Where do you guys buy them from?
Gary
e21Jason
Post Fri Dec 22, 2006 1:45 pm
Hi
Try plastics 4 performance
Jason
northloop
Post Fri Dec 22, 2006 6:47 pm
Thank you.
Gary
oguz327
Captain Armco
Captain Armco
Post Fri Dec 22, 2006 10:52 pm
Does anyone have any idea of the weight difference between poly and normal glass windows?
Post Sat Dec 23, 2006 2:12 am
stop it
northloop
Post Sat Dec 23, 2006 10:25 am
It's not as substantial as you might think. On a 205 it's someting like 14kg.
If I can I will have some though :cool:
oldroydsr4
Post Sat Dec 23, 2006 12:50 pm
Have been looking at poly windows to, do you think it would be better to just buy some poly and make your own using the originals as templates.
Several m^2 of poly = £30
Poly window set = £150+
Any differcults, has any one done this before?
baxter
Post Sat Dec 23, 2006 1:26 pm
£180 in the tweeks book!
Brian28
Post Sat Dec 23, 2006 1:38 pm
Found this the other day when I was looking for other stuff, not sure how up to date it is. S/H set for £50
http://www.laserchrom.com/body.htm
Brian
For sale - E30 320i racer project - sold.
m-dtech
Unapproved Trader caution
Post Tue Dec 26, 2006 1:02 am
i made my own on my xr3i rally car.
really easy to do.
Taffy
Post Sat Dec 30, 2006 11:05 am
Some of the poly kits really are crap and fit badly and the better kits are thermoformed to fit perfectly, weight saving is enough to make a difference but IMO the main benefit is safety, perspex doesn't shatter on impact! P4P are a quality company, part of the reason why I am a distributor! :wink:
please contact admin with regard to sig
funky-monkey
Post Wed Jan 03, 2007 1:34 pm
They dissolved in 2003
miniblob
Post Sat Jan 20, 2007 5:30 am
Mate of mine was helping prep a jag track car last year and just bought a sheet of poly, made the windows and pop'd them into place. Piece of cake apparently!!
327 Touring with bass!!!
Taffy
Post Wed Feb 07, 2007 5:46 pm
Depends if you want proper motorsport quality perspex that is thermoformed and cut to size, if you don't then any old crap will do!
northloop
Post Wed Feb 07, 2007 7:33 pm
Can you sort me a price out for my 4-door 325i please.
You can either pm me here or on Northloop.
Gary
charlE30
Post Sat Feb 10, 2007 12:39 pm
Just found this site that sell perspex windows...
http://www.xlraceparts.com/index.asp?fu ... ductid=527
BMW F31 335d xdrive
ed325i
Post Fri Mar 09, 2007 9:12 am
Prices and info for the BMW E30 window kits are below, Please take time to read the specifications on the materials at the bottom of the page
BMW E30 + E30 M3 window kit (Meets or exceeds current MSA / FIA specifications)
* Kit contains all windows except for the front screen
4mm clear FLEXIGLASS @ £180.00 + VAT
4mm clear POLYCARBONATE @ £200.00 + VAT
4mm bronze or grey POLYCARBONATE @ £200.00 + VAT
4mm clear LEXAN MARGARD POLYCARBONATE @ £380.00 +VAT
5mm clear LEXAN MARGARD thermoformed front screen @ £270.00 + VAT
Slider Kits @ £23.50 per door and are fully installed, these measure 210 x 210 mm as std
*FLEXIGLASS is a DOT approved safety plastic, available only from Plastics 4 Performance and we consider this to be a good all round material for all forms of motorsport except rallycross
*POLYCARBONATE - We only use genuine MAKROLON or LEXAN UV protected exterior grade materials which have DOT, ANSI and ISO approvals for use as safety plastic and all our polycarbonate kits are 100% polycarbonate, we do not substitute for lower grade materials in thermoformed screens
*LEXAN MARGARD POLYCARBONATE -Abarasion resistant polycarbonate kits, the material has a special hard silicon coating applied to both surfaces to combat scratching, Carries all safety certificates needed and we are proud to say that Plastics 4 Performance are the only suppliers of moulded hardcoat screens in the UK
Paul Davenport
Unit 10 locke Ind Est
Emmett street
Horwich
Lancashire
BL6 7PN
UK Telephone / fax 01204 696 609
International Telephone / fax +44 1204 696 609
Mobile 07890 513 398
eMail info@plastics4performance.co.uk
Web www.plastics4performance.co.uk
Taffy
Post Sun Mar 11, 2007 11:42 am
I presume these prices are for flat panels not thermoformed? It is good kit, just supplied a few of their kits and have some lovely grey smoked ones going into my E36 as I write
