Convertible battery placement
vmckague
Post Fri Dec 22, 2006 2:58 am
I have asked this question on quite a few groups over the last few years and no on seems to know the answer for sure. Why is the battery on the convertible E30 under the hood( bonnet) and not in the trunk(boot) like on the sedans? I do know there is a lead weight in the trunk to replace the weight of the battery so why not just leave the battery there?
mrLEE30
Post Fri Dec 22, 2006 4:25 am
no idea really, hs been discussed here too, removing this lead weight does not seem to make any real difference, but on mine removing it seems to make the brake pedal vibrate a bit more if i rest my left foot on it during normal driving, the lead weight is a vibration damper. i can only assume the battery is not in the back on a cab as the sills are different as is the additional bracing under rear seat/behind rear seat so perhaps there were cable routing issues. anyway i prefer it in the front, easier to jump start whe its flat as no need to remove my subwoofer.
Rosc0PColtrane
Post Fri Dec 22, 2006 10:37 am
As Mr Lee said, the weight distribution is probably the reason. The lead weight alters the resonant frequency of the car and prevents vibration
Demlotcrew
Post Fri Dec 22, 2006 10:48 am
M3 cabs have the battery in the boot.
Andrew
orangecurry
Post Fri Dec 22, 2006 10:51 am
The lead weight is not 'just' that - if you take it out and look, the fixing bolts go into rubber feet specially inserted into holes in the weight, which isolate metal-to-metal contact, or weight-to-chassis contact. The whole thing is like a crude LP turntable deck/feet, the idea of which is to stop feedback from the speakers reaching the stylus on the record...
you are expecting me to tell you why now aincha? I can only guess the same as the boys above; perhaps when BMW made the cabbie shell, they had a resonant frequency they couldn't shift, and some bright spark came up with this which solved the problem.
Rosc0PColtrane
Post Fri Dec 22, 2006 1:07 pm
Cheers Orange!! I was close tho!!!
Globulator
Post Fri Dec 22, 2006 3:25 pm
orangecurry wrote:The lead weight is not 'just' that - if you take it out and look, the fixing bolts go into rubber feet specially inserted into holes in the weight, which isolate metal-to-metal contact, or weight-to-chassis contact. The whole thing is like a crude LP turntable deck/feet, the idea of which is to stop feedback from the speakers reaching the stylus on the record...
It's pig-iron too, and quite heavy, definitely reduces scuttle shake when in place - I've tested this!!
No idea why they didn't leave the battery there tho.. unless for space?!
1986 325i 'vert, funk louder than standard.
"No Mr Bond, I expect you to tell me why your 4 litre, 282bhp sports car can't outrun some lardy old Mercs.."
Audio & electronic software: http://www.cutestudio.net
orangecurry
Post Fri Dec 22, 2006 9:42 pm
blatantarrogance wrote:Cheers Orange!! I was close tho!!!
eh? You were spot-on :D If we are right of course :o:
What we need to do is to write to BMW (Germany) and ask them... I'll get onto it :D (The power of the interweb!)
Ziggy
Post Sat Dec 23, 2006 12:59 am
I've definately read the same thing elsewhere... from a relatively official source too, IIRC :)
mrLEE30
Post Sat Dec 23, 2006 4:29 am
Eh????? you have a record player in your cab?? Technics 1210s?? and if you remove this weight does the needle jump??
orangecurry
Post Sat Dec 23, 2006 4:43 pm
Thorens TD160
the 'needle' doesn't jump; not with my wine-glass-on-the-bonnet driving, but you get low frequencies interfering with some of the clarinet solos
