catalistic exhaust
teebaur
Thu Dec 21, 2006 1:51 pm
hi all i have a 318i catalistic exhaust system and i was wondering if i could fit a non catalistic standerd exhaust system wud it fit? also were wud i plug the lambrough sensor
spence_star
Thu Dec 21, 2006 1:54 pm
jus get it de cat, get the cat takenn off
Returned after many years out.
teebaur
Thu Dec 21, 2006 6:17 pm
ay?
Templ8e30
Thu Dec 21, 2006 6:46 pm
What year is the car ?
If it's on a k-plate or later (1993) it needs a cat exhaust to pass emissions tests.
If it's pre-1993 then you can fit a non-cat exhaust. The Lambda sensor can then be removed from the car, the ECU will operate in open-loop mode the same as all E30's without cats.
Cheers,
Iain T
PS. Your spelling is crap :roll:
2007 Mazda 6 2.0 estate
jmc330i
Thu Dec 21, 2006 11:16 pm
Templ8e30 wrote:What year is the car ?
August 1992 (from K plate) is the date.
As was said on another thread, in most cases, as long as the car passes the emissions test, it should be ok for the MOT even without the cat.
James
'91 325i Sport
'93 318i touring 16v
