Original Sport Alloys - What size?
AndyS3
Post Wed Dec 20, 2006 8:40 am
Are they 7 x 15?
Whats the general opinion on the best size tyres to go for?
Favourite tyres in the past have been Goodyear Eagle F1's, any other suggestions?
Cheers all
Chris-W
Post Wed Dec 20, 2006 8:42 am
Yes.
205/55 is standard fitment, 205/50 also popular but a harsher ride.
orangecurry
Post Wed Dec 20, 2006 9:50 am
you can't get Goodyear Eagle F1 GSD3 in 205/55/15 :cry:
Everyone else (it seems) on the zone raves about Toyo T1R being as good as F1 GSD3s, but I have no personal experience of these. I currently have NCT5s and Uniroyals on my 15" wheels, and they are OK, but that's all.
A friend has some Toyo T1S fitted to his Lotus, and says they are shite.
GDBN
Post Wed Dec 20, 2006 10:13 am
Dunlop SP9000 sport ... great tyre.
G
AndyS3
Post Thu Dec 21, 2006 7:28 am
orangecurry wrote:you can't get Goodyear Eagle F1 GSD3 in 205/55/15 :cry:
Doh :cry:
Cheers for the recomendations fellas :thumb:
ian332isport
Post Thu Dec 21, 2006 10:09 am
I found the F1 GSD3 to be total shite on my car, but everyone else seems to rave about them. Maybe they don't work so well in 215/40/17 :?
I always seem to go back to Bridgestones, which seem to be consistantly good.
orangecurry
Post Thu Dec 21, 2006 10:16 am
I've just bought one (not for the E30) in 215/40/17 (don't ask why just one :mad: )
I've only had them in 205/50/16 before now, and they were stupendous, wet or dry, and kept the performance even when worn-down below the wear-bar.
ian332isport
Post Thu Dec 21, 2006 10:25 am
orangecurry wrote:???????????????
They never actually let go, but they felt horrible. I could feel the sidewall leaning over before it settled in the corner. I almost took them back it was that bad. I've since heard that they need a higher than standard pressure to stop them leaning as much.
Fitting Bridgestones back on was like night & day.
orangecurry
Post Thu Dec 21, 2006 10:43 am
I went FROM Bridgestones winkeye it was like night and day :D
perhaps they suit AWD jap-crap ? When you said you could feel the sidewall deform, did you mean front and rear, or just the driven wheels?
orangecurry
Post Thu Dec 21, 2006 10:45 am
and did you have the correct load index/speed rating? There were some problems (allegedly) with the sidewalls if the load index was too low for the car/weight/power.
maxfield
My dad doesn't rate these tyres.
he has them now just don't seem to grip enough in the dry.
looks like a set of toyo R888s is on the shopping list :D
orangecurry
Post Thu Dec 21, 2006 10:50 am
don't understand - the wife (who is a bit of a girl-racer) noticed instantly when I took the OLD worn-out/illegal GSD3s off her car, and put brand new P-zeros on (a friend recommended them, so I wanted to see for myself)...
She said "If you bung it into a corner, it feels all funny and the car squirms; it's even worse in the wet - all my confidence is gone"
It's a Prodrive Impreza, RB5-power spec.
AndyS3
Post Thu Dec 21, 2006 11:10 am
orangecurry wrote:don't understand - the wife (who is a bit of a girl-racer) noticed instantly when I took the OLD worn-out/illegal GSD3s off her car, and put brand new P-zeros on (a friend recommended them, so I wanted to see for myself)...
Not strange at all, I found the same when I changed from F1's to P-zeros on my S3, hence why in an ideal world I'd fit a set to my sport
orangecurry
Post Thu Dec 21, 2006 11:26 am
I just meant it was strange that people don't like/rate them, when EVEN WORN OUT, they are soooo much better than brand new P-zeros on my car;
but as I said, maybe the load index/speed rating on e.g. your dads car Maxfield isn't high enough? I would have thought he would have bought the highest :D
Andy - another tyre I've heard good things about are Vredestein Sportrac2? (56 GBP in 88V on mytyres)
But Toyo T1-R (88V load index/speed rating) are only 45 GBP on mytyres ! I'm tempted to try some myself (on the E30) at that price.
The Dunlop 9000s on mytyres are ZR rated, but cost 71 GBP.
maxfield
Post Thu Dec 21, 2006 11:30 am
orangecurry wrote: but as I said, maybe the load index/speed rating on e.g. your dads car Maxfield isn't high enough? I would have thought he would have bought the highest :D
the car doesn't seem to grip aswell as it could i think semi slick is the way forward.
my dad did prefer toyos t1-r to the gsd3s.
that was before new susp arbs etc so its kinda hard to compare.
or maybe michelin pilot sports he likes them too but are expensive.
orangecurry
Post Thu Dec 21, 2006 11:43 am
perhaps the suspension is now too hard for real roads, and you are going to get grip problems whatever tyre he chooses
maxfield
orangecurry wrote:perhaps the suspension is now too hard for real roads, and you are going to get grip problems whatever tyre he chooses
semi slick will certainly good enough for roads
and hopefully a track :D
orangecurry
Post Thu Dec 21, 2006 11:57 am
nahh - the opposite
if you make the suspension harder, the tyre (on a real road, i.e. one with lots of undulations/bumps in the tarmac) is in contact with the road surface for LESS of the time = less grip.
Same happens when you increase the rim diameter - you effectively REDUCE the side wall depth, and therefore the sidewall flexes less = the tyre is in contact with the surface for less of the time.
Of course on a super-smooth track, the above (make suspension harder and decrease sidewall depth) is EXACTLY what you want to do :D
orangecurry
Post Thu Dec 21, 2006 12:03 pm
I hope that woman in black got put in jail for hitting the woman in red, who wasn't even looking - what a cowardly act; and then running away as well.
Can we have the chicken chasing the kid back please?
maxfield
Post Thu Dec 21, 2006 12:04 pm
ah right
he might drop down to 17inch wheels yet so we'll end up with more sidewall and that means he can lower the susp fully :D
i think i should still make a massive difference with semi slicks even tho the might only last a couple of 100miles :D :D
the roads aren't that bad but we'll found out how well the semi slicks are (if he does decide to buy them)
orangecurry
Post Thu Dec 21, 2006 12:08 pm
no - roads ARE that bad :D
without getting arrested or run-over, kneel down on a few roads, and have a good look. Then do the same on your next track-visit. There's a HUGE difference.
Roads are deliberately make with undulations/bumps/holes in the tarmac (and the whole road has a camber), to assist with water run-off and reduce aqua-planing, and to give EXTRA grip WHEN BRAKING, which is what most people who drive on normal roads want :D
maxfield
Post Thu Dec 21, 2006 12:13 pm
on a track i'll get run over extremly fast altho it would be instant but i don't want to die.
ill just take your word for it :D
snoops
Major Helmet
Post Thu Dec 21, 2006 9:45 pm
are pirelli p6000 any good?
orangecurry
Post Thu Dec 21, 2006 10:30 pm
Compared with any of the tyres mentioned above? No.
As a safe, strong, long-lasting quality tyre, yes.
