HELP,(again),I have a 316i touring in which the courtesy/interior lights never worked,(lights are located each side of headlining above centre posts). When I removed the lights I discovered one had no connectors to put the wires to! Bought new lights,(ebay),and pulled wires from inside headlining and connected to lights,not only did they not work but now the two E/W switches on the centre console are permanently lit up even when the car is switched off and locked!
Any suggestions (a)what wires go onto what connections on the interior lights? (b)how can I resolve the E/W switc lighting problem? and (c)could these problems be related? I have now removed all wiring from the interior lights,E/W switch problem persits and have disconnected the battery! Thanks for any help forthcoming, JOHN.
E/W switches permanently alight!!!!
Chris-W
bigjprogs
Thanks,I'll check the switches,ruled out being possessed by Satan-he would have bought the 325i!!
Short answer is: your car was previously owned by a muppet!
Wires to the interior lights are red/green 12V+ permanent live to one end of the light.
Brown (earth) and brown/purple (from door pin switches) to the two blades on the other end.
The looms from each light run straight down the rear door hinge pillars to black plugs where they plug into the main loom at cill level.
As for the window switches - They seem to permanently powered. They should be fed from fuse 17 with the front doors closed and the ignition on, and from fuse 28 with the front doors open.
Pull these two fuses in turn and see which kills the switch lights.
bigjprogs
So you knew the previous owner! It appears that 'the muppet' decided to rip out all of his 13! speakers and their cables with no regard to the future owner,THIS MUG!,just spent a few months renewing all of the interior panels to replace the speaker gaps,now I'm getting the wiring hassle! Still better than going shopping with the 'enemy' many thanks for your help-John.
