seeing as the ports are round,
can this be fliped 180degrees and everything still line up?
line up with the head ports that is, (including studs!)
manifold!
Turbo-Brown
- Boost Junkie
Which engine?
If you're talking about an M20, then no is the short answer.
Turbo-Brown
- Boost Junkie
You thinking about doing a turbo jobby then?
The manifolds can be flipped but there's a mountain of metal to be removed before the ports line up again, and then there'll be a big mismatch over on one side I shouldn't wonder.
Manking your own manifold isn't too difficult if you can weld and have a hacksaw
