Retrofitting front fog lamps
FlashBastd
Post Tue Dec 19, 2006 6:20 pm
Ok, I have done a search and come up with some, but not all of the necessary info.
I want to retrofit front fogs to my E30, I believe that I will need the following;
2 x fog lamps, with brackets
1 x 2 button fog lamp switch
1 x relay
What I would like to know, is what else do I need, and which relay is it? What will the number on the relay be?
Will I need a bulb for my instrument cluster?
What about clips to accept the screws for the fog lamps?
Finally, do I also need some additional fuses?
Thanks for your help!
1993 E30 318i Lux Auto Touring - SOLD
2001 Ford Mondeo 2.5 Zetec-S 5dr - SOLD
2004 Lexus IS300 Limited Edition Auto - SOLD
2005 Honda CR-V 2.0i Executive Auto
2001 Ford Puma 1.7i Black
gazza
Post Tue Dec 19, 2006 6:43 pm
if i remember correctly its relay k8 but willing to be corrected
yes you will need the bulb for the cluster
8 plastic clips and 8 screws from bmw about £3
2 extra fuses
and off you go
FlashBastd
Post Tue Dec 19, 2006 7:42 pm
nice one, thanks.
Is K8 the position of the relay, or the reference / part no?
jcjdavis1
Post Tue Dec 19, 2006 8:11 pm
Hi I have recently done mine.K8 is relay position 2x7.5 fuses in position 29/30 (I think) marked on fuse box lid and away you go.I managed to put bulb in cluster without taking the hole thing out by undoing all nuts and screws then tilting the top back and and fix in bulb from the bottom.I hope this helps.
FlashBastd
Post Tue Dec 19, 2006 8:39 pm
Thanks, but I could really do with the actual part no of the relay, which should I think be printed on it.
FlashBastd
Post Wed Dec 20, 2006 10:37 am
Anyone know if the relay is the same type as for the rear fogs? I have a spare one of those knocking around.
Thanks!
geo1400
Post Wed Dec 20, 2006 3:08 pm
I don't know part numbers but it's black, square has 5 pins and is the same as 1 other relay in the fuse box!! I''ve just retro fitted fronts and I had a spare relay aswell, it just happened to be the right one.
