EBC brakes
Hyperion
Post Tue Dec 19, 2006 3:49 pm
Hi Guys
Has any one had experiance with EBC brakes, i am thinking of upgrading my front discs and pads to these. Any good or bad experiances etc.
thanks
Hyperion
Post Tue Dec 19, 2006 3:59 pm
orangecurry
Post Tue Dec 19, 2006 4:01 pm
I have, but not on an E30
pads only (not the discs):-
Redstuff - a bit harsh for day-to-day driving, but very good
Greenstuff - very good for fast-road driving, but didn't last very long
Hyperion
Post Tue Dec 19, 2006 4:05 pm
thanks orange
what do you mean the red stuff is "Harsh"?!? do they work too well?!?
orangecurry
Post Tue Dec 19, 2006 4:17 pm
they are either 'on' or 'off'
pootling round town, you try to slow down gently, and nothing much happens, so you apply a bit more pressure and stop instantly 8O
barrelling into a roundabout at 130mph, they are perfect to wash off the speed (and they do it at the next roundabout just as well)
they are ceramic, but road-legal (so they work from cold)
horses for courses - Greenstuff are still very good, but are a compromise. Redstuff are not :D
Hyperion
Post Tue Dec 19, 2006 4:22 pm
cool, info much appriciated, all i need now is to find someone who has put the discs and pads on a e30 :)
orangecurry
Post Tue Dec 19, 2006 4:40 pm
OBC do say that if you buy their discs to complement the Greenstuff pads, the pads last a lot longer than if you use stock O/E discs, but I assumed that was marketing to get you to spend more money with OBC....
I've just worn out a set of Mintex M1144s on the same car - I think the Mintex are very good with stock discs, falling nicely between the Redstuff and Greenstuff with abillity, but always felt the Mintex started to fade sooner than the Greenstuff (but the Mintex lasted 4 months longer, the Greenstuff only lasted 12 months).
The problem with brakes is that unless the car AND discs AND pads AND brake-system condition are not EXACTLY the same, you can never say that e.g. Pad A is better than Pad B, because all the other factors make a huge difference.
powelly
Post Tue Dec 19, 2006 4:43 pm
orangecurry wrote:they are either 'on' or 'off'
What he said, the experience I had was on a Dolomite so 130 is very ambitious, in fact it`s down right dangerous, Green stuff is fine for fast road and most track work unless your going real quick, lots brake dust though, was forever cleaning my wheels.
Image Le Mans Classic 2006
Hyperion
Post Tue Dec 19, 2006 4:46 pm
true , i understand what you saying, maybe, i should just give them a try, just let my pads wear out a bit more. Will get the discs and pads (green) and i will take some pictures and do a little post about them some time later.
pnd
Post Tue Dec 19, 2006 6:05 pm
BRAKE DUST AND SQUEAL FROM THE pads wouldnt recommend.
Hyperion
Post Wed Dec 20, 2006 8:07 am
hi pnd
were you running the groved discs and green pads?
FlashBastd
Post Wed Dec 20, 2006 12:46 pm
I ran redstuff on my Mondeo for 12m / 20k miles and they were pretty good, that was with OE discs. I know it is a very different car, but I would agree with what Orangecurry said, except that I didn't find them "too" bad for day-to-day driving, but if I had kept the car I would probably have gone back to OE, i.e. I wouldn't have gone for them again. While on a trip to the Nurburgring there was no sign of fade after 3 hot laps, but given that I only seem to make one pilgrimage per year, the trade-off in terms of feel when cold jut didn't really seem worth it.
1993 E30 318i Lux Auto Touring - SOLD
2001 Ford Mondeo 2.5 Zetec-S 5dr - SOLD
2004 Lexus IS300 Limited Edition Auto - SOLD
2005 Honda CR-V 2.0i Executive Auto
2001 Ford Puma 1.7i Black
jmc330i
Post Wed Dec 20, 2006 1:03 pm
Hyperion wrote: were you running the groved discs and green pads?
I ran the EBC grooved/drilled discs and greenstuff pads on my Sport. They worked ok and they did get used winkeye but they only lasted 8 months or so before I was getting bad vibrations whilst braking.
Ive used greenstuff pads on OE discs and they were fine, but I wouldnt recommend the EBC discs at all for the E30 - I say that because I know a few people with Fords and Vauxhalls that run them no problems.
James
'91 325i Sport
'93 318i touring 16v
**BANNED**
Post Wed Dec 20, 2006 3:22 pm
I am using Greenstuff pads on both E30s with standard vented discs.No problems,the dust washes off with less sticking to the wheels.they look almost unworn after 10000 miles on the 316,we mus^nt drive fast enough!!
pnd
Post Wed Dec 20, 2006 3:52 pm
greenstuff pads on standard discs Id spend the money on brake cylinders will probably improve the brakes further. E30's can stop alright but most dont and thats not purely down to discs and pads in my experience.
Pal318is
Post Wed Dec 20, 2006 10:01 pm
I have the gooved and drilled discs with pagid fast road pads..If i was honest the discs have been a pain in the arse, trying to get them to sit flush on the hub seemed surprisingly difficult, why i don't know...but since i've had them, I get the wobbles at about 50-60mph...I'm planning on changing them in the new year for either ATE or OE, but still using the pagid pads, they seem pretty decent.
Pal
Pal
Image[img]http://Image
fuzzy
He who sleeps with "Gingers"
Post Wed Dec 20, 2006 10:05 pm
i dont agree at all .i have EBC drilled /grooved discs all around with red ceramic pads on the front and greenstuff on the rear and its the set up i will always use .i find them great when cold and even better when hot.the ceramic pads just wont fade and just keep gripping no matter how much abuse i give them.and i give them a lot winkeye they do wear out that little bit quicker i think and i tend to replace the front pads every 6 months with the rears being yearly
Motorhole
Post Thu Dec 21, 2006 12:55 pm
I found Rally Design's "Group N" discs pretty decent. Can get them plain (as mine were), grooved or grooved and drilled (although I don't agree with drilled discs myself). It was an improvement over standard, not massive but definitely there...main thing is that the discs were £33+VAT for the pair winkeye
