heated rear window not working
SPADGE
Hi people
The heated rear window on my 320 2 door has never worked and as i ocasionaly use it as a runabout it would be nice to be able to see out of the rear window!
The switch doesn't light-up when you switch it on.
I'll try the switch 1st but if its not that what are the most likely culprits?
Fuse , relay???
Cheers Spadge...
Fuse , relay???
Cheers Spadge...
SPADGE
Just tried a known good switch and it made no difference what so ever so whats next folks?
DJ_B4L
have you checked the connectors on the back window are they connected?
PIONEER AVIC X1, X1R, X1 BT LATEST SATNAV DISK WITH LATEST MAPS AND ALSO UPDATES FIRMWARE £20 POSTED PM FOR MORE DETAILS
Number plate for sale E30 2 HRD open to serious offers only will suit any E30
SPADGE
Yes mate but as the switch doesn't even light-up i'm guessing the problem is live feed related?DJ_B4L wrote:have you checked the connectors on the back window are they connected?
smithy318i
Fuse 8 (30A)
SPADGE
Cheers matesmithy318i wrote:Fuse 8 (30A)
Have checked all the fuses that one included and all are fine!
fugazi33
Hi mate, have you tried the relay? It controls the heater blower as well, is that playing up?
SPADGE
No mate the heater blower is working fine!fugazi33 wrote:Hi mate, have you tried the relay? It controls the heater blower as well, is that playing up?
This car has air/con though so it may not be the same?
You done with my afm yet?
fugazi33
Mmmm, could be different, i'll have a look in a bit, Yes I'm done with the afm, might need to borrow a throttle body though
SPADGE
I'll rent you onefugazi33 wrote:Mmmm, could be different, i'll have a look in a bit, Yes I'm done with the afm, might need to borrow a throttle body though
oze30
Classic!SPADGE wrote:I'll rent you onefugazi33 wrote:Mmmm, could be different, i'll have a look in a bit, Yes I'm done with the afm, might need to borrow a throttle body though
smithy318i
Okay then, if it isn't the fuse you need to unplug the demist switch and check:
1: that you have 12v from the green/blue wire at the demist switch.
2: you have 0V at the black wire at the demist switch.
this is a very simple circuit which goes from the fusebox (fuse
to the switch, to the heater element, to the bodywork.
report back what you find.
SPADGE
Will get the meter out tomorrow mate cheers!smithy318i wrote:Okay then, if it isn't the fuse you need to unplug the demist switch and check:
this is a very simple circuit which goes from the fusebox (fuseto the switch, to the heater element, to the bodywork.
fugazi33
Oy you, don't encourage himoze30 wrote:Classic!SPADGE wrote:I'll rent you onefugazi33 wrote:Mmmm, could be different, i'll have a look in a bit, Yes I'm done with the afm, might need to borrow a throttle body though
oze30
hey.. he ripped into me about an air comp!!! alls fair in cars and parts!! ;)
