NUTS (and bolts), where's this from?
Post Mon Dec 18, 2006 8:51 pm
Bell housing bolts are torx though, top 2 are both 12mm aswell, starter bolts are 10mm and the lower 8mm bolts are also torx and are much shorter so get gearbox out of your head :)
Chris-W
Post Mon Dec 18, 2006 8:52 pm
PAS pump?
Post Mon Dec 18, 2006 8:54 pm
How much noise? If its only short lived it could be someone has replaced a rack mounting bolt with that, they should be 10mm so if they have used an 8mm bolt then they may not have used a locking nut either.
victoruk2
The steering noise could be because the car is stood still. Try moving it back and forth while you are turning the wheel.
reddevil
Post Mon Dec 18, 2006 8:58 pm
the car was mobile while making this noise, didn't change if it was stationary, was always there. The steering is pretty noisy, worse than I have ever heard it before (and it is always noisy), is shortlived, groaning while the steering wheel is being turned, but then once the pressure is off ie, not being turned anymore then it's back to silence.
1991 (H) 318iS Diamond Black, M-tech II spoiler.
K&N Panel filter-Viper2 chip-Zone BBTB
XBOX LIVE - reddevil1976
**BANNED**
Post Tue Dec 19, 2006 4:23 am
I vote with smithy318 on this.Last time I was under my 320i one of those exhaust clamp to gearbox bolts had gone awol.
Brian28
Post Tue Dec 19, 2006 9:22 am
Any movement wriggling the PAS pump? PAS pump mounting bolt gets my vote. (This should have been set up as a poll :D :D )
For sale - E30 320i racer project - sold.
SPADGE
Post Tue Dec 19, 2006 9:52 am
Brian28 wrote:Any movement wriggling the PAS pump? PAS pump mounting bolt gets my vote. (This should have been set up as a poll :D :D )
The PAS pump bolts are quite short and so it won't be from there mate
reddevil
Post Tue Dec 19, 2006 10:15 am
Right Guys, the results are in........DRUM ROLL.
The winner is...........
Power Steering Pump.
So whoever said that wins a fondue set and a cuddly toy.
The bummer was I got charged £26 for a replacement bolt :x :x :x
Still, at least it's done.
Thanks for all the many thousand replies.
Red Devil :cool:
SPADGE
Post Tue Dec 19, 2006 10:56 am
I was totally wrong then :cry:
I have never seen a bolt that long attaching a pas pump though in my defence :P
Glad you got it sorted even if the steelers pulled your pants down big time :eek:
