M40 Problems
bmwe30mtech
Post Mon Dec 18, 2006 9:17 am
Hey Guys,
I started my car this morning for the first time in 2 days, and it wasnt particuarly smooth.
I know the tappets/cams are slightly worn or out of alignment due to the tapping. It also keeps cutting out when cold if you rev it at all.
I will try it again tomorrow but film it and put up a video.
Any help would be great,
Paul
orangecurry
Post Mon Dec 18, 2006 9:46 am
my M40 failed when the inner/upper oil 'sump' bolts worked loose, and the oil take-up seal opened, allowing air into the oil-pump = engine totalled as I was on the motorway.
It might be too late by the sound of it *if* that is what has happened to you. You can try taking off the 'outer' sump, and see if you find some bolts lying in there (they drop down from the inner/upper 'sump').
2nd-hand M40s don't cost very much - it's finding one you know is good that is difficult.
Andyboy
Alpina Colada
Post Mon Dec 18, 2006 1:02 pm
That sounds like a Piston issue. I'd be taking that engine out and throwing it in a skip. They're a pice of cake to swap though and someone here will have one.
bobafett
Post Mon Dec 18, 2006 1:06 pm
Sounds like "orangecurry" has hit the nail on the head mate. Loose or missing upper sump bolts. Your engine is trying to lube itself with air rather than oil. Get it sorted or you could be looking for a new engine my friend. :cool:
What ?! Drive straight officer......It's an E30 !
It's the Ultimate Drifting Machine.
orangecurry
Post Mon Dec 18, 2006 3:27 pm
nahhh I'm never right; he wouldn't be losing oil if it was just the oil take-up seal, but what I described might be the CAUSE. As I said, best off finding another M40 with known history in anticipation :(
smithy318i
Post Mon Dec 18, 2006 3:31 pm
probably valve stem oil seals or piston rings.
bmwe30mtech
Post Mon Dec 18, 2006 7:42 pm
Thanks for the responses.
Where can i find the oil sump bolts? I take it you mean the sump, as in the sump on the bottom of the engine? I didnt think the problem would be down here. I will check it in the morning.
Welcome to the zone bobafett, i hopefully wont reach the need for another M40, but maybe will have no choice.
Smithy, i immediatly thought piston rings also. Where are valve stem oil seals located?
For now i will just put more oil in and look it all over.
bmwe30mtech
Post Mon Dec 18, 2006 7:44 pm
Andyboy wrote: I'd be taking that engine out and throwing it in a skip.
Dont tempt me, i dont have a replacement yet!!
I will get a video of the noise up soon.
Ant
Retired Team Member
Retired Team Member
Post Mon Dec 18, 2006 7:52 pm
Dude, I have an M40 in a breaker @ the mo, quiet as the grave from cold/hot, revs right out and fast-ish for the 1.8 :lol:
yours if you want it dude, still in car, can be run if you bring a fuel pump,seat and steering wheel with ya :thumb:
bmwe30mtech
Post Mon Dec 18, 2006 7:56 pm
Ant wrote:Dude, I have an M40 in a breaker @ the mo, quiet as the grave from cold/hot, revs right out and fast-ish for the 1.8 :lol:
Hi Ant,
Sounds ideal, a smooth 1.8 m40, got to be a rareity! If im honest i have no way of transporting an engine, and dont have a hoist for moving one, so am slightly stuck :( . Cheers for lending me the tools for lowering my car, i would ask if you would be kind enough to lend me the use of an engine hoist but i dont see it fitting in my boot this time!
pm sent :)
Paul
Andyboy
Alpina Colada
Post Mon Dec 18, 2006 11:35 pm
Take the car to Ant and get him to swap them over. A day's labour plus the mill ain't going to cost a great deal. Either that or rent a van for an hour, twenty sheets should do the trick.
Considering most M40's are as wanked as yours, this is not an opportunity to miss.
cliffybabe
Powered by Nelly
Powered by Nelly
Post Tue Dec 19, 2006 12:09 am
Paul I could help ya mate, I could pick up the lump in my transit for ya mate
bmwe30mtech
Post Tue Dec 19, 2006 9:59 am
cliffybabe wrote:Paul I could help ya mate, I could pick up the lump in my transit for ya mate
Hi Niel,
That sounds like a plan mate. I just spoke to Ant and the engine is still in the car, so i will need to get it out somehow first, want to lend a hand :D ? Once its at my end its only a 1.8 so me and a few mates will be able to manover it.
I will pm you mate, cheers,
Paul
bobafett
Post Tue Dec 19, 2006 10:03 am
Hi Niel,
Paul
Sounds like an all nighter going on ! Don't forget the coffee, biscuits and porn ! The all help to keep you awake trust me.......Especially the PORN ! :D :D :D
bmwe30mtech
Post Tue Dec 19, 2006 12:50 pm
Right, i went out this morning and changed the oil and filled it up nicely. She started fine. Pure clear fumes, the lot. Went round the block and no blue fumes etc.
Still taps of course, but i have yet to see an M40 that doesnt! I guess it was because it had been standing for a few days. I looked at 'my records' and i changed the oil last at the beginning of the summer, so not as recently as i thought. Maybe i can accept that its burnt a bit since then, i done about 8k miles since summer :? .
Now im in two minds whether to leave it alone and wait untill i put a 2.5 in in the summer time, or put Ants 1.8 in. :?
DJ_B4L
Post Tue Dec 19, 2006 1:45 pm
paul put a 2.5 in be much more power and your car is all done.
PIONEER AVIC X1, X1R, X1 BT LATEST SATNAV DISK WITH LATEST MAPS AND ALSO UPDATES FIRMWARE £20 POSTED PM FOR MORE DETAILS
Number plate for sale E30 2 HRD open to serious offers only will suit any E30
