MrDazzle
Post
Mon Dec 18, 2006 6:05 pm
Hi,
By shuffle, I mean does it kangeroo (well not quite as severe) when you make sudden changes to the throttle?
Best way to highlight it is to drive at about 20mph in second gear at a constant throttle then either stamp on the pedal or suddenly let off the pedal. The car should judder back and forth slowly (about once a second).
Well, mine does anyway....does yours? Trying to figure out if something is wrong.
maxfield
MrDazzle
Post
Mon Dec 18, 2006 6:10 pm
Well no, 'cause it only appears when you make suddent changes in throttle input.
320Touring
Post
Mon Dec 18, 2006 6:19 pm
sometimes a worn diff bush can give you the joys of " driveline shunt"
mine does it whan you get below 1200rpm in 5th.
sometimes its bad enough so I have to change to 4th
parts aint expensive, but rather you than me to take the diff out....
MrDazzle
Post
Mon Dec 18, 2006 6:27 pm
It's got poly diff mounts that are pretty new.
I think it's an artifact of having a big long and quite floppy (
) prop shaft. Or it might be a worn out 2-mass flywheel?
Post
Mon Dec 18, 2006 6:32 pm
or your big rubber prop coupling up by the gearbox has split or the centre bearing is shagged. Probably 1 of the 2
325bhpbruiser
Post
Mon Dec 18, 2006 6:41 pm
gonna be down to wear and tear and possibly bushes, had this on my disco not so long ago not i know the drive train is not as simple as these but it turned out to be a mix of uj's and main shatfs in the boxes being shagged.
FBF
Post
Mon Dec 18, 2006 6:45 pm
maf unit.
im so sexy justin brought me back 5 times
maxfield
MrDazzle
Post
Mon Dec 18, 2006 6:47 pm
I thought driveline shunt at first, but it doesn't seem that way to me....
THe repsonse is (excuse technicalness;)) more sinudsoidal than step, if that makes sense. I.e. it's more of a 'wooo----woooo----wooo' than a 'wump'.
Chris-W
Post
Mon Dec 18, 2006 6:49 pm
So more fuelling than mechanical?
325bhpbruiser
Post
Mon Dec 18, 2006 6:54 pm
air flow prob perhaps? possibble leak on a breather or the below, if you wanna go down that route i would say air fuel mix.
Silverfang
Post
Mon Dec 18, 2006 7:22 pm
Sounds like what i had, the idle control valve kept sticking (ICV)
Easily sorted by flushing with WD40
MrDazzle
Post
Mon Dec 18, 2006 8:18 pm
My engine doesn't look like that
The six pipey things aren't there, I've only got 4 going across the engine bay...the engine isn't as 'long' as that either. Do I have an ICV?
Chris-W
Post
Mon Dec 18, 2006 8:22 pm
Yours is at the rear of the intake manifold. On the pic above, it would be near the B of 'throttle body'..
maxfield
Post
Mon Dec 18, 2006 8:33 pm
MrDazzle wrote:My engine doesn't look like that
you've got a 4pot then
MrDazzle
Chris-W
Post
Mon Dec 18, 2006 8:51 pm
Four cylinders, as opposed to six in the pic.
325bhpbruiser
Post
Mon Dec 18, 2006 10:41 pm
LMAO! anyone got a pic of a 4 potter with icv circled for him, must have been confused to fook when he saw that pic then though of his lol
billgatese30
Post
Mon Dec 18, 2006 11:03 pm
Silverfang wrote:Sounds like what i had, the idle control valve kept sticking (ICV)
awwwwww, doesn't she look nice
also, carb/brake cleaner is better for cleaning the ICV out, rather than WD40
Post
Mon Dec 18, 2006 11:11 pm
Yeah, my car kangaroos a bit too, particularly from a cold start. Mind you, I've just noticed a fairly severe fuel leak underneath the rear of the car (hose going into the fuel filter has developed pin-holes), which isn't going to help! I plan to clean my ICV and fit a Miller MAF in place of the flappy AFM thing.
325bhpbruiser
Post
Tue Dec 19, 2006 12:45 am
yer nicley done bay that
ian332isport
Post
Tue Dec 19, 2006 1:54 am
MrDazzle wrote:drive at about 20mph in second gear at a constant throttle then either stamp on the pedal or suddenly let off the pedal.
If I stamped on the pedal in 2nd gear, while rolling at 20mph, I would mostly generate smoke
mrLEE30
Post
Tue Dec 19, 2006 4:25 am
valve guides or piston rings then sir , you need to look after that big S52 better....
MrDazzle
Post
Tue Dec 19, 2006 5:40 pm
325bhpbruiser wrote:LMAO! anyone got a pic of a 4 potter with icv circled for him, must have been confused to fook when he saw that pic then though of his lol
I'm just being silly mate
I have a degree in Automotive Engineering and I work for Rolls-Royce as a design engineer on Nuclear Submarines! I know the difference between a 4 and 6 cyl engine
It still doesn't seem like a fueling problem to me though, 'cause it appears at both tip in and back out, but isn't efected by weather, engine temp or any other things you'd expect to effect fueling.
Post
Tue Dec 19, 2006 5:45 pm
It's your shaky right foot then - must be a side-effect of the nuclear fall-out
gareth
Post
Tue Dec 19, 2006 5:57 pm
ian332isport wrote:MrDazzle wrote:drive at about 20mph in second gear at a constant throttle then either stamp on the pedal or suddenly let off the pedal.
that's the downside of your silly small capacity
multivalve engine. mine will do that in 3rd at 10mph!!! also good for towing trains
toby
Post
Tue Dec 19, 2006 6:06 pm
I've experienced similar kangarooing. This could be many things. If it is only a slight lurch then a worn engine mounting or propshaft donut coupling could cause symptoms like this. As you accelerate the worn bush or coupling allows stuff to move more than it should - then the vibration or kangarooing kicks in.
If it is more severe kangarooing it could also be the rotor arm in the distributer starting to break up. Again this happened to my car and began with slight jerkiness and then ended on the full tigger scenario. This shows up when you suddenly speed up and make the resistance accross the gap greater. As you accelerate the sparks can't keep up with the fast moving rotor arm as the resistance accross the gap is too large because the rotor is worn. I opened my distributer cap when the kangarooing got really bad and the rotor arm was in about 200 tiny pieces. Stuck a new one on and no more jerky bastad.
325bhpbruiser
Post
Tue Dec 19, 2006 8:42 pm
ncie choice of career mrdazzle, wasnt meat to offend btw!
mrLEE30
Post
Wed Dec 20, 2006 4:30 am
no offence mate but i worry for the future of the nation if an automotive engineer degree holder who works for Rolls Royce designing nuclear subs, or parts within, refers to the inlet manifold as pipey things!! i am glad i am in the middle east, a seemingly safe part of the world!!
mlree
- **BANNED**
Post
Wed Dec 20, 2006 5:26 am
My freshly rebuilt 2.7 does this,I have sealed all the joints in the inlet system,cleaned the ICV and checked the breather pipe.Then a zoner suggested that the radial springs in the clutch plate were loose...next time I am underneath the thing I will grope the propshaft to see if there is any play there...anything to avoid pulling the box off....
Chris-W
Post
Wed Dec 20, 2006 7:47 am
mrLEE30 wrote:i am glad i am in the middle east, a seemingly safe part of the world!!
mlree
"Always head straight at the accident, on the assumption it won't be there when you arrive"
MrDazzle
Post
Wed Dec 20, 2006 6:00 pm
daimlerman wrote:My freshly rebuilt 2.7 does this,I have sealed all the joints in the inlet system,cleaned the ICV and checked the breather pipe.Then a zoner suggested that the radial springs in the clutch plate were loose...next time I am underneath the thing I will grope the propshaft to see if there is any play there...anything to avoid pulling the box off....
This seems like the most likely thing to me...that or the dual mass flywheel is a bit dodgy.
I certainly hope it is the flywheel, that gives me a convenient excuse to fit an alloy one
Martinaston
Post
Wed Dec 20, 2006 7:01 pm
I don't think they have a dual mass flywheel, as in the modern term for it. Its more like a double the mass flywheel on the M40.
Sounds like clutch springs to me, try idling along in fifth and it will probably do the same thing.
It doesn't help to try and diagnose it when the gearbox bearings have seen better days.
There is NO nucleus.
