LSD
nolc
Can you tell if an LSD is fitted without taking it out and looking ?Local lad scrapping a 6 cylinder 2.0 reckons it has one fitted.
mwarrior
spinning the back wheel when its jacked up is the best sighn if the other wheel spins in the opposite direction then you have lsd..........i thing someone may need to back me up on this one
Theo
Yup - easiest way is to jack the car up on the diff so both rear wheels are of the ground (remember to chock the front wheels) Have the car out of gear with the handbrake off, spin one of the rear wheels, of the other one spins in the same direction - it is an LSD!
nolc
Im thinking same as you,just better to ask
Steve-E30
- East Sussex Hooligan
Both wheels should spin the same way with a Lsdmwarrior wrote:spinning the back wheel when its jacked up is the best sighn if the other wheel spins in the opposite direction then you have lsd
Richy325iTouring
same directionmwarrior wrote:spinning the back wheel when its jacked up is the best sighn if the other wheel spins in the opposite direction then you have lsd..........i thing someone may need to back me up on this one
Theo
When I posted the 'yup' was in response to the initial post, not the advice from the first chap!
DJ_B4L
so if they spin in the same direction this its a LSD?
or if they spin different ways then its a LSD
which one?
which one?
PIONEER AVIC X1, X1R, X1 BT LATEST SATNAV DISK WITH LATEST MAPS AND ALSO UPDATES FIRMWARE £20 POSTED PM FOR MORE DETAILS
Number plate for sale E30 2 HRD open to serious offers only will suit any E30
Same direction = LSD
Opposite direction = Open
DJ_B4L
thanks for that
cliffybabe
- Powered by Nelly
2 thick black lines lef ton the road behind u is the easy way to find out
Douzeper
Would jacking one side up and trying to spin the wheel by hand not give you the same conclusion?
Doesnt spin by hand - LSD
Does spin - open
Does spin - open
http://www.ni-bmw.co.uk
Northern Ireland BMW
cliffybabe
- Powered by Nelly
no cos u cant see if both wheels spin the same way
Douzeper
Yer probably right but..... if it was LSD it wouldnt spin? if it was open it would?
No?
No?
jpboost
Douzeper's right,
If the car's got a slipper, and you only jack one wheel, then it's difficult to turn. as it's pretty much linked to the other wheel that's not moving. Not impossible to turn though, I can turn mine (just) by hand. I think they can get easier to turn as the diff wears. Mine's rebuilt less than 5k ago FWIW.
Can't you just fill an open diff with thick grease to get the LSD effect?
H35-IAN
hehehee just put it on full lock and drop it at about 4k rpm lol if u can do rings u got a slipper if u start spinning just a wheel its a homo diff!!
so be carefull in this weather either can be good fun tbh but lsd pisses on homo open diffs!
bmw 328i sport e36
billgatese30
homo diffH35-IAN wrote:hehehee just put it on full lock and drop it at about 4k rpm lol if u can do rings u got a slipper if u start spinning just a wheel its a homo diff!!
Richy325iTouring
not a def there eithercliffybabe wrote:2 thick black lines lef ton the road behind u is the easy way to find out
ive left 2 lines with an open diff
quite a few at lakeside can confirm that
think booty blaimed some chavs in a nova after me and karan pratting about
Globulator
'ss easy. An LSD links the two wheels together.
Stick car in neutral
Disengage handbrake
Retrieve car
Chock front wheels
Disengage handbrake, check for neuttral.
Jack up ONE read wheel.
If it is very difficult to turn you've got an LSD - as it's trying to turn the other wheel
If it moves pretty easily you haven't, as propshaft just spins.
Disengage handbrake
Retrieve car
Chock front wheels
1986 325i 'vert, funk louder than standard.
"No Mr Bond, I expect you to tell me why your 4 litre, 282bhp sports car can't outrun some lardy old Mercs.."
Audio & electronic software: http://www.cutestudio.net
clubfx2
Nice response cliffy, that's how i'd check it tooo....
Regards
Clyde
Go everywhere sideways...
Clyde
ash-e30
yes sounds right or u could just toe and heel it n find out if both wheels light up or spin her round see if it goes round easy enough as u can normaly tell if u try and donut as it will push on or you can hear 1 wheel spinmwarrior wrote:spinning the back wheel when its jacked up is the best sighn if the other wheel spins in the opposite direction then you have lsd..........i thing someone may need to back me up on this one
yz_250
Normaly only the 325is,M3 and the 333i got lsd and 318is was optinal lsd but other then that the other e30 was open saw it when i did some resurch on lsd a wail back !
"Sorry under the influence of driving in style"
