My dreaded boot leak is back
he30
Post Sun Dec 17, 2006 7:48 pm
My dreaded boot leak is back, have fitted a new boot seal, new light seals and i'm struggling on where to go next? any of you guys come across a similar problem? it just seems to be gathering in the jack compartment :cry:
Ideas please.
march109
Post Sun Dec 17, 2006 7:54 pm
umm silly question time, do you notice the leak after a run in the wet? or when the car is stood?
I had this problem turned out I had a hole under th wheel arch and driving in the wet kicked the water up and in the hole!
bmwe30mtech
Post Sun Dec 17, 2006 8:05 pm
Do a search a few posts like this in the last week.
HTH
jmc330i
Does it only happen after its rained?
I say this because mine was fine in the rain, but I noticed the puddle had appeared in the summer (after a very long hot and dry spell) and also after it had been locked in my mates workshop for a week.
It was condensation on the inside of the rear quarter collecting in the rear well. The rubber bung in the bottom does have a hole to let water out, but this had become blocked.
James
'91 325i Sport
'93 318i touring 16v
he30
Post Sun Dec 17, 2006 8:09 pm
[quote="jmc330i"]Does it only happen after its rained?
It was condensation on the inside of the rear quarter collecting in the rear well. The rubber bung in the bottom does have a hole to let water out, but this had become blocked.[/quote
Yeah seems to collect when it's stood and has been raining? Theres quite abit too around 2/3 inch there.
bottlecapE30
Post Sun Dec 17, 2006 8:11 pm
jmc330i wrote:Does it only happen after its rained?
that is what happened with mine. no leak just condensation on the boot lid. I popped it one day to find the lid was covered in water droplets. no fix really unless your willing to put insulation on the lid.
1987 2.7l e30 m20b27 supercharging
1991 3.5l e30 m30b35 it is dead so sad
1985 3.5l e23 m30b35
jmc330i
Post Sun Dec 17, 2006 8:14 pm
he30 wrote: Yeah seems to collect when it's stood and has been raining?
Sunroof drain?? I think the pipe runs down into the rear quarter and often comes away from the bit of plastic that directs the water outside through the vent in the quarter panel.
James
'91 325i Sport
he30
Post Sun Dec 17, 2006 8:15 pm
Exactly the same as mine, boot lids covered, seems too much water for condensation mind.Can't seem to find any wet bits of trim though where it runs down?
he30
Post Sun Dec 17, 2006 8:17 pm
How do you get to that?
jmc330i
Post Sun Dec 17, 2006 8:25 pm
Remove the boot lining (passenger side) and it should be right in front of you.
James
'91 325i Sport
he30
Post Sun Dec 17, 2006 8:37 pm
jmc330i wrote:Remove the boot lining (passenger side) and it should be right in front of you.
Cheers fella, i'll give it a look :D
Post Sun Dec 17, 2006 9:52 pm
You'll find another one on the driver's side.
Check the inner arches carefully, especially the right hand one. Any bubbling of the paint is a rust hole.
jmc330i
Post Sun Dec 17, 2006 10:01 pm
Yeah sorry, I only said passenger side because thats where he said the water was collecting.
James
'91 325i Sport
Post Sun Dec 17, 2006 10:38 pm
jmc330i wrote: Yeah sorry, I only said passenger side because thats where he said the water was collecting.
My fault - didn't read that far back in the thread.
bmwe30mtech
Post Sun Dec 17, 2006 11:36 pm
Brian im amazed at how helpfull and knowledgeable you are when it comes to E30's. Also that you follow through peoples problems usually untill they fix them, eliminating one thing at a time. Just thought i should say what an excellent zoner you are, not that im sure you dont know it :) . (no im not drunk, just reading through a lot of the tech help posts!)
ian332isport
Post Mon Dec 18, 2006 2:22 am
Another often overlooked source of leaks are the hockey stick trims on the rear pillars. The plastic clips that hold these in place can crack and leak water into the boot.
Ian.
he30
Post Wed Dec 20, 2006 7:50 pm
ian332isport wrote:Another often overlooked source of leaks are the hockey stick trims on the rear pillars. The plastic clips that hold these in place can crack and leak water into the boot.
Ian.
I'll give it a look too, cheers to all and a merry christmas!
jcjdavis1
Post Wed Dec 20, 2006 9:33 pm
Hi I had water coming in via the ariel,put your hand up to where the ariel comes in and see if it's wet. winkeye
ChizFab
Post Wed Dec 20, 2006 10:20 pm
i decided to take a different approach, and drilled a very small hole at the lowest point of either rear tub in the boot.
lol a bit pikey but i dont have a swimming pool either side of my boot anymore :)
Now breaking.... e36/e34/e39 all models pm for parts!
Post Wed Dec 20, 2006 10:23 pm
There is actually a hole there, near the front where there is a join. The hole is formed by a small crease it the lower part of the metal where it overlaps, but is usually blocked by sealant.
chief
Post Thu Dec 21, 2006 12:48 pm
have a look under the wheel arch at the plastic inner arch that covers the outside of where you saying. if the holes are not sealed then water will get in there as the wheel splashes straight on to it. and if the drain plug is naff then it will collect and stay there for a very long time.
HTH
Don't you wish there were a knob on the TV to turn up the intelligence? There's one marked 'Brightness', but it doesn't work.
