Hi
does anyone know if there is a workshop in yorkshire which can replace the rear plastic window on e30 convrtible. how much is it going to set me back.
thanks
Convertible Rear Window Replacement
gazza
if it is a late window then it is zipped in and will take you a couple of hours to do ...if it is a early one then it is stitched and has to be done proffessionaly ...look at ebay for a new window i bought a very good second hand one for £60 and did it myself the old window was out in 10 minutes and the new within 1/2 hour but then it gets fiddly as you have to glue the surround in and let it set ...and the metal clip that secures the zip is a bit hit and miss
lukescott
My cab is a K reg april 93 model. I cant say I've ever noticed any type of zip mechanism around the inside at all. Are all late ones zipped ? I need to open my garage and have a look.
gazza
should be zipped look from the inside. or from the outside peel a bit of the hood back if you can see the zip then you have the easy option all later ones are zipped unless you have had it swopped for a second hand one from an older car
orangecurry
is it torn/broken?jazzleeds wrote:Hi
thanks
If not, and it has just gone opaque (cloudy!), buy a product from Renovo to clear it - it's hard work but it's one of those very rare products in the world which REALLY WORKS
http://www.renovointernational.com/prod ... polish.php
jazzleeds
mine is the 1991 325i convertible. the rear window has been stitched and i have two cracks in it. i need to get it replaced.
