e32 730i
gooner1
- Out humping Reindeer
Anything worth taking off the above for the m30 conversion.Its an 88 car btw.Thanks all.
mrLEE30
the M30 part of it!!
gooner1
Thanks for that mr LEE. Hope there,s a big f/off scorpion in your boots
Andyboy
- Alpina Colada
Are you using a 3 litre M30 then??
Ant
- Retired Team Member
Cant see the point TBH dude, M30B30 is barely more poky than a decent high comp 2.5, add in the weight penalty and I see no real gain
335 or bust
the work involved is the same, but the gains are greater
335 or bust
Email FTW
Andyboy
- Alpina Colada
Mind you, 192 standard and the cam in these is so tame it would run away if you shouted at it. It'd be good with a snail and MS.
gooner1
Sorry didnt explain that very well, i already have 535i sport engine was just wondering about things like flywheels
hoses diffs gearbox anything really.,
Ant
Now you're talkingsnail and MS
Email FTW
Andyboy
- Alpina Colada
Is your 730i a manual? In which case the gearbox is the same as a 3.5 and you have a dual mass flywheel. The only bits that swap over to the 3.5 engine wise are...the air flow meter....er....throttle body.........gooner1 wrote:Sorry didnt explain that very well, i already have 535i sport engine was just wondering about things like flywheels
If you still have a complete car I might have to come and rob some bits.
gooner1
What bits are you after Andy?
Andyboy
- Alpina Colada
There's not much I need tbh, I run a manual 730i and I broke up a 735i Auto a few weeks back so I already have a mountain of bits. Have u got the whole car or is she in a breakers?
gooner1
Breakers mate.Just that i happen to have first shout on bits.
Andyboy
- Alpina Colada
Aaaah. Okay, no worries. I was in a breakers the other day near Banbury (Smiths of Bloxham) and there were several E32's in there - lots of E34's too including a LHD 535i with a buggered gearbox and a 535i Sport.
gooner1
Keep meaning to make a trip there myself.Thanks for that.
mrLEE30
sorry mate
and we wear sandles for that very reason!!!
