Sump strengthening plate
Post Fri Dec 15, 2006 9:30 pm
Look at this beauty :cool:
kam-325i
Post Fri Dec 15, 2006 9:35 pm
Nice looking plate, shame about the welding..... :eek:
Post Fri Dec 15, 2006 9:50 pm
Welding is a bit dodgey but the plate makes up for it :)
kam-325i
Post Fri Dec 15, 2006 9:55 pm
Its likely to fall off.......Aluminium welding is not very foregiving like steel....I would personaly recommend you grind out those welds and put a bit more power into it, around 180-200A.
gazza
Post Fri Dec 15, 2006 9:56 pm
is that one of those things that are used for ploughing out speed bumps or stopping rpg7 missiles ...
Post Fri Dec 15, 2006 10:21 pm
kam-325i wrote:Its likely to fall off.......Aluminium welding is not very foregiving like steel....I would personaly recommend you grind out those welds and put a bit more power into it, around 180-200A.
Not mine mate (M3 in the background gives it away), I found the pics and thought I would post em as it does look a nice bit of plate :D
kam-325i
Post Fri Dec 15, 2006 10:33 pm
It is a nice piece of work, and a good idea...
Mmm.....what have we got in the scrap aliuminium bin a work....... winkeye
jmc330i
Post Fri Dec 15, 2006 10:48 pm
Is that meant to be a replacement for a sump guard?
Seems like a good idea, but not sure about it in practice. One hard hit and its likely to either crack off or take a chuck of sump out.
Think Id prefer a sump guard that isnt fixed to the sump.
James
'91 325i Sport
'93 318i touring 16v
Post Fri Dec 15, 2006 10:56 pm
Deffinatley a proper sump guard would be my first choise, but you cant deny that it adds strength to the sump for skimming over speed humps etc, obviously if you hit a missplaced curb stone on your local A road its going to fall apart :)
jmc330i
Post Fri Dec 15, 2006 11:18 pm
DanThe wrote:but you cant deny that it adds strength to the sump for skimming over speed humps etc,
Im not so sure. Just seems to me that some weak points have been introduced.
If you were to skim a speed bump with that plate, surely it would put pressure on to just the welded points and so be more likely to crack the sump underneath. At least if a 'normal' sump skimmed a speed bump you wouldnt get a concentrated pressure point.
I like the idea and it looks cool, but Id be less worried with a normal unprotected sump.
James
'91 325i Sport
Post Fri Dec 15, 2006 11:27 pm
But the sump is about 2mm thick :?
If I threw that plated sump at a brick on the floor then did the same with a standard sump I know which one my money would be on winkeye
jmc330i
Post Fri Dec 15, 2006 11:53 pm
I agree the plated bit will be stronger - its thicker. I just feel the welds are the weak point and its not going to offer anymore protection or is going to lead to more stress/damage around those areas.
If the sump was to skim a speed bump, then it would take the pressure from corner to corner for example and something thats 2mm thick will take more load/stress when its spread over the whole area, compared to something 2mm thick taking the same load over a thinner area (the line of the welds in this case).
Fixing the guard driectly to the sump just seems a bit odd to me.
James
'91 325i Sport
boomer
Post Sat Dec 16, 2006 7:24 am
Dry sump it and be done with it :D
