Direct Starter Motor
Quaser
Post Wed Apr 06, 2005 9:56 pm
Hi
I need to connect the starter motor direct cause i think the ignition switch is broken!
So, which pole on the starter motor do i need connect to the battery?
Q
Post Thu Apr 07, 2005 12:04 am
Black/yellow wire is the starter wire.
You can access it at pin 11 of the diagnostic plug, at a single pole plug and socket above the glove box, or the plug and socket clipped onto the steering column.
Widge
Post Thu Apr 07, 2005 1:19 am
Or you can just short the solenoid contacts on the starter with a screwdriver, I suggest one with a big plastic handle and some gloves.
Entirly at you risk or you may end up like this :clin:
Post Fri Apr 08, 2005 12:07 am
Service connector is easiest, especially as you have 12V+ on pin 14.
Just short 11 and 14 to work starter.
