my car goes through a set of rear tyres in 6 month!!
elliott
hello can anyone help me please, i bought my 325 sport already lowered with 17" wheels on, not sure how low it is but as an example the rear arch just covers the top of the tyre, seen lots of e30 like that on here!! my problem is my car eats a new set of rear tyres in just 6 months, only the inner edges! as i already know its cos the camber is wrong but does everyone else have this expensive problem!?
maxfield
you could try camber plates
or getting some -35mm springs
m3ben05
elliott
i was thinking of raising it, but have seen others this low
SCOTT325SE
thats -60 front, -40 rear.
i had a 325 with 15s and tyres lasted AGES! Swapped them to 17s and was killing them twice as fast!
If you must keep the 17s, sort the camber.
If you must keep the camber, sort the alloys or buy new tyres and expect to keep buying them!lol
blingsta
- Boost Junkie
they look and handle real nice when that low, but ive been through the same thing too mate... just get the standard rear springs back on and tyres will love it.. you will feel the difference in handling straight away, i almost lost it staright away on a slight bend, but it makes you a better driver and you will also have better tyres
Nelly
- Gumbo
SCOTT325SE
PMSL. Yea, it does mate. lol.Nelly wrote:Feck it, i like the look of lowered E30's and would put up with buying tyres when needed - also depends on who you know for tyres as well init Scott![]()
Neil.
exup
- Boost Junkie
Where can u get chamber plated from ?maxfield wrote:you could try camber plates
pnd
-35 and 15 inch wheels the best all round solution why people bother with anything else is a mystery.
Dan318-is
You cant use camber plates at the rear. you need eccentric trailing arm bushes; either bmw or powerflex do them.exup wrote:Where can u get chamber plated from ?maxfield wrote:you could try camber plates
