Couple if silly little problems with my iS I'd like to fix..
MrDazzle
Post Wed Dec 13, 2006 9:28 pm
Hi,
Got my new iS off of Kos this weekend, had it 5 mins and already a couple of things are bugging me.
1) The interior lights don't come on when you open the drivers door, but they do when you open the passenger door. Bizarely, the electric window switches iluminate when you open either door.
2) I can't unlock the car from the passengers door. Not really a problem, since I have to unlock the driver's door to drive the thing!
3) There's a tiny crack in the dashboard, cosmetic only.
4) The smoked indicators are quite dim. Are there LED's or something avaliable to brighten 'em up a bit?
Anynoe have advice on fixing any of the above? The rest of the car is so clean these little things bug me. If I can fix them the car will be perfect, instead of just excellent :)
Post Wed Dec 13, 2006 10:09 pm
1/ Drivers door pin switch. There are two switches in one; one for the interior light and one for the windows.
Take it out and clean it up. Look carefully for a sliver of black plastic that forms between the contacts and trim it off, lubricate with silicon grease and refit.
Don't let the wires spring back through the hole in the door pillar when you have the switch disconnected.
2/ Why? Key doesn't turn? Deadlocked? How do you lock the doors before you can't unlock it?
3/ Change the dash. A lot easier than you might think.
orangecurry
Post Thu Dec 14, 2006 1:00 pm
4/ go back to the indicator covers that God intended winkeye
Royalratch
Post Thu Dec 14, 2006 1:12 pm
You can get really bright LED bulbs for the side repeaters from Cooks Ferry in Enfield.
The fronts should be fine with regular Orange bulbs.
Kos
Post Thu Dec 14, 2006 3:11 pm
are you on about the front indicators or side repeters ??
you can get led bulbs for either mate, any car accesory place can sort you out
door lock, i've never unlocked the car from the passenger side !!
also interior lights, i never noticed that LoL
but i know what you are on about, wanting the car to be perfect.
MrDazzle
Post Thu Dec 14, 2006 5:12 pm
Front and side repeators....
Already changed the side to plain white ones, since one blew anyway. They're alot brighter but obviously not orange!
The passenger's door lock is having none of it, refuses to turn whatever I do.
Post Thu Dec 14, 2006 9:12 pm
Still not clear on this!
If you use the key on the driver's door, the passenger door locks and unlocks as you turn the key?
You can unlock a locked passenger door by lifting the lock pin inside the door?
You can push the key into the passenger doorlock, but it won't turn?
orangecurry
Post Thu Dec 14, 2006 9:34 pm
MrDazzle wrote:Front and side repeators....
I believe that'll be an MOT failure.
Chris-W
Post Thu Dec 14, 2006 9:36 pm
Oh yes.
MrDazzle
Post Thu Dec 14, 2006 10:19 pm
Well I cleaned the door switch up, so we can cross item number 1 off the list :D
stuartgallafant
Post Fri Dec 15, 2006 9:39 am
ya see, she's nearly perfect!!
MrDazzle
Post Mon Dec 18, 2006 5:57 pm
Right door lock situation is this:
Drivers Door - Works both locking and unlocking the car. However, unlocking you have to turn the key a bit clockwise first, then all the way anti-clockwise. The whole mechanism feels a bit stiff.
Passengers door - Only works locking the car, i.e turning clockwise, moves with a nice positive smooth action. Is too stiff to turn anticlockwise to unlock.
Boot - Fine, nice smooth positive action locking and unlocking.
Any suggestions?
Spotted problem number 5) The dash clock (analogue) doesn't light up. Is it supposed to?
And number 6) Headlight level adjust doesn't work. This is a common one isn't it?
Chris-W
Post Mon Dec 18, 2006 6:14 pm
Headlight level adjust almost never works. Clock should be lit, yes. Single bulb to replace.
Post Mon Dec 18, 2006 11:10 pm
Both door locks need to be removed and to be given a good clean and grease up. Couple of adjustments can be made as well.
I've posted several times before on the procedure, so use the forum search function.
