Touring speakers
Post Mon Dec 11, 2006 10:11 pm
I know this must of been asked before but i want some bigger speakers in the rear of my touring shed
apart from building a shelf (they could then be hidden under the load cover) the only thing i could think of would be to mount them on the side doors. The ones which hide the jack,tool kit, first aid etc. I expect this is far from ideal but i can't think of alot else
anyone?! :?
oze30
Post Mon Dec 11, 2006 10:27 pm
I had 6x9's cut into my door bins. But I sold them with the turd!
Cotty
Hartge Crew
Post Tue Dec 12, 2006 8:07 pm
Simon13 wrote: the only thing i could think of would be to mount them on the side doors. The ones which hide the jack,tool kit, first aid etc. I expect this is far from ideal but i can't think of alot else
anyone?! :?
I have seen larger speakers further forward ie almost under the load cover in the sides. If you think about it there is space as thts where the touring speaker pods would reside. I cant find a pic to explaine properly
The doors probably wouldnt be a good idea as they are quire flimsly and have strengthening vaines on the back which you would need to cut out to mount the speakers.
dips346
London Meets Main Man
Post Tue Dec 12, 2006 8:13 pm
Simon13 wrote:I know this must of been asked before but i want some bigger speakers in the rear of my touring shed
anyone?! :?
jonb had a set for sale with 6x9 in them
dark_sounds
for speakers you need a sturdy bass for the midbass,
fiberglass is your friend ;)
or realistically just upgrade the front ones and amp them to compensate,,, forget the rearfill unless youve got passengers alot of the time.. most compitiion setups only have front components and rear sub, thats all you really need .. if its good enough to compete with im sure its good enough for you...
Directed CompX's 12"... 2off. 1000 watts RMS, dual 2ohm VC. 90£ each!!
8600 Luna Phone 480 POSTED BNIB
Post Tue Dec 12, 2006 10:40 pm
Ah thats the next problem i have no front speakers so wired one up to the speaker wires and.........nothing!
Looks like i'll have to go that route then, i've got some half decent 6 inch jobbies see if i can get them to go
cheers!
dark_sounds
Post Tue Dec 12, 2006 11:24 pm
ill have a look at it tommorow for you si, want me to bring my tools?, cutters crimpers cables and terminals? ill try and sort out some front end sound for you at least, also got some shitty 5.25" spakers you can chuck in just for te time being if you want. dont want anything for them, just take them:)
Post Wed Dec 13, 2006 5:21 pm
cheers dude! :D
Richy325iTouring
Post Wed Dec 13, 2006 5:25 pm
better off with the shelf si
some tw@ has put them in the rear fold downs on the one i have ow and with stuff in the back you cant hear then and it looks shite
make a shelf and hide them under the load cover will sound loads better
