Hi guys,
i locked my car the yesterday and when i came back to ,it all of about 2mins later, it wouldnt unlock. it normally locks off the alarm or from the boot but it just wouldnt let me in. After a quick visit from the rac man, he opened it with a pair of pliers on the key in the passenger door. He said the door had deadlocked itself but i thought it could only do that from the drivers door??? anyway i got back in and he pushed the door, still locked, closed. so now the passenger door is locked closed and the rest of the car is open. Has nyone experienced this before, or have any suggestions??? So far the plan is to get back in and lube all the mechanisms up, will this work??? Thanks Chris.
stupid door locks
If it had deadlocked itself, then you may have problems. Usual cause is water getting into the locking ECU, activating the locks and deadlocks, and then frying the motors.
The maintenance on the mechanisms is a good idea. Often find that the locks and key barrels go stiff through lack of use on cars that are always locked by remote.
padi
Thanks mate think ill strip the doors down and do that. Thae really stupid thing is it let me into the car just 5mins earlier off the remote with no problems and it locked as per usual... The locking ecu is behind the drivers footwell speaker isnt it??? Thanks for the help.
padi
Just spoken to a mate at my local bmw dealer and he said to check the micro switch in the drivers side door. Think ill start here as he seems to think that could lock the passenger door.
