e30 foglight,please help, left light not working!
anton
Post Sun Dec 10, 2006 10:32 pm
hi guys,
i hail here from cape town south africa, i imported 2 x foglights, 1 from germany and 1 from america, 2 different sellers. non-cracked lenses. mine were cracked. before i swapped em, my right side driver side foglight stopped working, before i changed the foglights. i figured a bulb or something. so tonight i swapped both foglights for my newer non cracked foglights. anyway., the driver right side foglight still isnt working.
so i figured check the fuses. both checked out fine.
next i figured either a break in the cable or a short, out come the multimeter.
i have verified both ground and positive right on the plug that plugs into the driver side foglight. theres power and ground...
cant understand it..
any help???
ciao
Anton
kevin316i
Post Sun Dec 10, 2006 10:39 pm
Could be the connection in the back of the foglight. Check for any signs of corrosion and give them a good cleaning.
Post Sun Dec 10, 2006 10:45 pm
Put the meter away - it gives misleading readings on unloaded circuits!
Find a 5W 12V lamp with a couple of pieces of wire connected to it (an old E30 side indicator repeater is ideal) and test again with that.
anton
st00pid me, obviously if there is power at the plug then it must be the bulb!!!
its 12:41am here and i wasnt thinking straight. both light i put in are 2nd hand but in good nick. i.e no cracked lenses.
i just replaced one of the bulbs with that from the old set and presto it worked!
strange strange co-incidence that the driver side foglighbt i imported also had a blown light bulb. weird eh.
anyways. alls fixed and she now has non-cracked foglights. yay!
cheers
Anton
