hi.. can anyone advise me on a cheapish solution to the brake fade problem with my 325ise saloon. it has drilled vented front discs and standard rear drums.
all linings and cylinders are new and ok but it still fades like mad when braking from high speed.
have considered a rear parachute!!!
e30 brake fade
eltel
Only in the good lord we trust.. In everything else we check!!
1988 325i Tourer, Lowered, Deep Dish Alloys, Obc, Cruise Control, Heated Leather Sport Seats....
maxfield
a decent set of pads
braided lines
and some decent fluid
al that should do the job
braided lines
eltel
cheers!
320Touring
TBH i'd be concerned that my 325ise had drums at the rear... all 325's that left the factory had rear disks..
pnd
"hi.. can anyone advise me on a cheapish solution to the brake fade problem with my 325ise saloon. it has drilled vented front discs and standard rear drums." I thought all 325's had discs all round change brake cylinder to sort out problem of rubbish brakes along with braided hoses and good pads.
DaveD
- E30Zone Wiki Specialist
the discs at the rear have a drum incorporated for the parking brake
I think 320Touring probably knows that, but most people, when discussing the rear brakes, aren't referring to the parking brake.DaveD wrote:the discs at the rear have a drum incorporated for the parking brake
Does this 325 have vented front discs?
eltel
mine has rear drums as it started life as a 320i se and i dropped the 325 into it... thought that the 325 rear discs were optional on saloon and standard on tourers but you know more than me.
may look at changing the lines and fluid.
They were. All tourers, cabs and 325 saloons have vented front discs and solid rear discs, but any E30 saloon ordered with the ABS option would have the same.eltel wrote:thought that the 325 rear discs were optional on saloon and standard on tourers .
gcorky
- Boost Junkie
Brianmoooore wrote:They were. All tourers, cabs and 325 saloons have vented front discs and solid rear discs, but any E30 saloon ordered with the ABS option would have the same.eltel wrote:thought that the 325 rear discs were optional on saloon and standard on tourers .
http://www.e30zone.net/modules.php?name ... nespec.htm
conflicting info...is this zone pricing rollocks or what ...tourings with drums?
