325i Sport Servicing
AndyS3
Post Sat Dec 09, 2006 8:34 pm
Evening fellas
Bought a sport this afternoon, collecting it next Saturday
Could you give me a list of the best quality parts you use for a service
I havent got a clue whats used but a local garage will be doing all the fitting
Cheers in advance :thumb:
MONSPORT42
Post Sun Dec 10, 2006 11:21 am
That's a big open-ended question. I guess you need start with what it's going like, what it looks like and what trusted info you have from the previous owner. First thing I would do is get a new timing belt in - they need changing every 30-40,000 miles (open debate) and unless you know for sure when it was done last it is not worth the risk of it going and mess it will make of your engine if it does. The rest are normal service parts you'd get for any car. Air filter, oil filter, new set of plugs. The dealers aren't that expensive for these although you could save a few quid at somewhere like GSF. I've always used Magnatec (the expensive one) for oil. I've got an auto so don't know about gearbox oil but it's nothing special. You'll have a slipper on the Sport and you will need to buy the right diff oil which is quite expensive. Depends how far you want the service to go but check the brakes - wheels off. Standard brake pads are fine for normal use but quite a few use Ferodo which fade less under frequent use.
I'm sure others will come in with more things and other opinions!
YOUR LEFT FOOT'S FOR BRAKING
pnd
Post Sun Dec 10, 2006 11:24 am
bmw oil filter and oem air filter or performance panel filter eg k+n or itg, good quality semi synthetic oil and ngk plugs and renew the fuel filter and change coolant. Also if there is no recent record of it being done change cam belt and tensioner for peace of mind.
Post Sun Dec 10, 2006 11:38 am
Best parts to use are genuine BMW bits from the dealer, but these are usually (but not always) the most expensive.
BMW genuine parts are usually far cheaper than genuine parts for other makes of cars, and you can buy parts of parts as well. (e.g. beam adjusters for the headlamps - any other manufacturer you'd be buying a complete headlamp.)
Eurocarparts and GSF also source spares from the OE manufacturers, so you can get the genuine BMW bit in a different box without the BMW stamp. Often cheaper than the dealer, especially on fast moving parts, like service items. They also sell some rubbish as well, so beware.
Change the cam belt tensioner pulley as well, and it's usual to change the waterpump as well at the same time.
Check the distributor cap and rotor while it's off, and replace if they're showing signs of wear, although they are a bit on the expensive side.
Don't replace the plug leads - they last forever.
AndyS3
Post Sun Dec 10, 2006 2:57 pm
Cheers fellas
Getting a list ready for when I collect the car next week, there isn't much history with the car so Im gonna have a thorough service, much appreciated :wink:
orangecurry
Post Sun Dec 10, 2006 5:33 pm
if you go to your local BMW dealership, and say you are in the trade, you will probably get a discount
cambelt B93.24.0.00.006 15% discount = 14.67
roller (pulley) B11.31.1.711.153 10% discount = 39.45
plus VAT of course
get their coolant as well - it is good. :D
