When idling, the gearbox on my Sport makes a slight "chattering" noise. It also feels quite notchy and stiff for the first few miles when driven from cold!
I've heard the best remedy for this is to change the oil for a thin fully synthetic gear oil.
I want to know which oil is the best to use in your opinions (grade, manufacturer etc...) and also what is the best oil to put into my LSD.
Any advice will be much appreciated.
Gearbox chatter!
Phatz
Templ8e30
Quite a few E30 gearboxes chatter at idle, it's to do with wear in the layshaft bearings iirc and it's nothing to worry about.
Be aware that a thinner oil whilst giving easier cold shifting will also give more noise when hot
Cheers,
Iain T
Cheers,
Iain T
2007 Mazda 6 2.0 estate
Phatz
Oh right, so other than having the gearbox reconditioned is there nothing else I can do to combat the "chattering"?
Cheers mate!
Cheers mate!
