slip diff???
tommyg
how do i tell (visualy) if it is a slip diff. What phisycal differances are there if any. And how does one maintain one???????? Tommy.
simys
it is hard just by looking i don't think you can. but if you can turn the input (prop) and one wheel will turn clockwise and the other will turn anti-clockwise. also if you hold one of the outputs (half shaft) and it should stop turning if it is not a lsd.
but if you are buying one i would replace the seals gasket, and replace the oil and check the teeth for damage and heat damage. also check the input bearing for play by pushing and pulling up and down on the input there should be no movement apart rotation movement.
nickphine
All you have to do is jack both rear wheel up in the air and turn one of them.
If they both turn the same way it's an LSD.
If turn in opposite directions it's a normal diff.
If it's off the car it will also be stamped with an S on the casing in front of the ratio stamp.
You'll also need different drive shafts, the LSD casing is larger than a standard one and the drive shafts are slightly shorter to accomodate it. I know this as I bought some standard replacements and they were too long! I think the M3 ones are identical.
Cheers.
Cheers.
Chris-W
